Question about Whirlpool GD2SHGX Refrigerator
The cicuit drawing and label of a refrigerator
Draw and label circuit a diagram of a refrigerator
3 Suggested Answers
  • 62 Answers
SOURCE: water inside of refrigerator running down into bottom, right draw
tHE MOST COMMON PROBLEM IS THAT THE DEFROST DRAIN BLOCKS UP AND CAUSES THE DERFOST MOISTURE TO OVERFLOW INTO THE REF SECTION. TO REMEDY THE PROBLEM YOU COULD LEAVE THE UNIT OFF FOR 24 HOURS AND THE ICE WILL MELT OUT AND FREE THE DRAIN, OR YOU COULD TAKE THE COVERS OFF AND REMOVE THE ICE AND TRY TO FORCE SOME VERY HOT WATER DOWN THE DRAIN WIT HA TURKEY BASTER. THE DRASIN IS LOCATED BEHIND THE EVAP COVER. OR YOU COULD CALL A SERVICE PERSON
Posted on Dec 02, 2008
  • 41 Answers
SOURCE: vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Posted on Dec 12, 2008
Change the filter. Fruits Vegetables
Posted on Sep 11, 2015
How do i get the kw capacity of a fridge freezer
Hi Wendy,
It isn't really a kw "capacity", but an expected draw. I take it you are concerned about the circuit capacity? Generally there is a data plate on the appliance that shows the maximum rated current which is what it will draw with all the compressors, motors, lights etc operating. If you have the amps you can calculate the power as you will know the voltage as well. I was prepared to offer this web site
Home Energy Magazine Database for Refrigerator Models and their Energy...
But you indicate you have already found the rating. If you check their rating methodology, you can probably tease out the KW from that.
Here is also a video that may be of use:
Jan 09, 2015 | Refrigerators
Wiring diagram?
Go to the mfg website and see if one is available to download. Go find a similar unit and take some color pixs if no book can be found. Good idea to draw a diagram and label wires before taking off if you are not familiar with unit.
May 05, 2014 | Refrigerators
The refrigrator tempreture is 56 degree and every time I reset it to 36 it comes out 56 degree. the refrigrator is very warm from inside the freezer is ok. what is the problem?
The best way to determine what has caused a non defrosting GE electronic control model is to first access the control board. Jump terminals line power to defrost, (J4 and J9). An amp probe should be placed on this jumper wire to determine current draw of the defrost circuit. A three amp draw is what is normal for this circuit. This will eliminate checking behind the evaporator cover to determine a defective heater or over temp device (defrost terminator). Note: This test is only to check the defrost circuit. It does not initiate a defrost cycle. If the unit is in any other cycle than defrost, that cycle will continue to operate as well.
Jul 12, 2011 | General Electric Profile PFCS1PJXSS...
I printed out the KF24 pictoral diagram and had to draw a ladder diagram for our HVAC training course in order to troubleshoot the system in the lab. In trying to rectify the Evaporator Defrost heater...
first try putting controls in series with loads. Remember, loads consume power and switches pass power. Start here. If I had a copy of your drawings, I'd be in a better position to address your situation.
Oct 04, 2010 | Beverage-Air Beverage Air KF24-IAS 20.7...
The indoor ice and water dispenser has lost power ? ...fridge and freezer working great ...its making ice just fine, is there possibly a fuse blown for the dispenser
Click here for a parts manual=> GD5YHAXNL00 Page 13 shows the 4 parts that make up your dispenser board, overlay and components. Click here for the user manual=> GD5YHAXNL00 And of course the wiring diagrams=> GD5YHAXNL00 and revision #2 Tech Sheet # 2305869 If you need assistance with this, I can assist you. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
May 22, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
We are not sure what electrical outlet is needed for the master bilt model blg-27hd
Hello I can help you. First of all here is a link to the owner manual in case you don't have one. In the manual you will see answers to all of your questions:
http://www.kclcutsheets.com/PDF/MB%5Cblg.pdf
Your model requires a dedicated 120 volt outlet with a 20 amp circuit breaker In other words, a regular outlet but not one that has lots of other appliances using that same circuit because, this refrigerator alone draws almost 15 amps of power.
Aug 07, 2009 | Master Bilt BLG-27HD Refrigerator...
Ground fault trips once turned on.
Either the receptical is wired wrong, or the line safety limit has been exceeded(example If you have a 20 amp breaker and the draw on that breaker exceeds 20 amps the breaker will trip.) You either have to put the refrigerator on a dedicated circuit or trace the circuit that it is on to see if the total load on that circuit is greater than the circuit limit. The simplest being , put the refrigerator on its own circuit.
Jul 18, 2009 | Dometic Refrigerators
Kenmore side by side refrigerator (model 50542001)
THE SUSPECT YOUR COMP HAS LOCKED UP AND IS TRIPPING THE BREAKER,IF YOU HAVE A METER YOU CAN CHECK THE AMP DRAW,LOOK ON THE COMP. AND YOU WILL SEE THE LRA DRAW-MIKE
Mar 01, 2009 | Kenmore Refrigerators
Power draw on start up
When the compressor first starts up it can draw as high as 15 amps but for no more then a second or two. After that it should run at 1-1.5 amp and will draw less as it continues to run. After 10 minutes it should pull anywhere from .5-1 amps.
Nov 04, 2008 | Haier White 2.7 Cu. Ft....
Whirlpool GD2SHGX Refrigerator Logo
416 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
