Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Oven does not work although stove does
We have a GE Profile gas oven model # JGS968SEK!SS. When I turn the oven on it says 100 degrees but than never warms up. This happened before and then suddenly it started working. Now it wont work again?
  • mflood2009 Feb 21, 2009
    Same problem. Any help would be appreciated
  • Anonymous Mar 17, 2009
    stove and broiler works great BUT the stove shows 100* when I want 350* and it never gets hot
  • GE Master
  • 3,361 Answers
Check and or replace the glow bar ignitor.
Posted on Feb 21, 2009
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Self Cleaning Gas Range F2 Error, happens at 400 degrees and turns oven off any advice?
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Gas stove oven wont turn on
Put a new iginiter for the oven on your stove.
Mar 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
962 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
