Question about Microsoft Xbox 360 Console
Power on but no red lights. No picture on the monitor, no problem with monitor tried xbox on another monitor same problem just shows that monitor is in gaming mode.
  • 27 Answers
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heat guns and work just as good. the last thing you need is Arctic Silver 5 which can be found for 5 bucks on eBay. now once you have this you need to lay your motherboard on a flat inflammable area. light the torch and make sure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top of the chips are cleaned with a paper towel of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to adjust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small screwdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
THIS WILL REPAIR 3RED LIGHTS,FREEZING,NO VIDEO, 2 red LIGHTS. in most cases 1 RED LIGHT will be fixed
GO TO A HAREWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Posted on Feb 22, 2009
I hadn't had my xbox 360 on all day and when I turned it on it had 3 red rings. No picture is showing up on the TV and the light on the power supply is green.
That is the red ring of death...if your XBOX is less than 3 years old call Microsoft tech support and they will arrange for a replacement unit.
Jun 15, 2011 | Microsoft Xbox 360 Console
My x box 360 surge box shows a orange standby light but my console will not turn on this happened the other day
i believe its red because if u r positive its not red then i would like to see a picture
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 13, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 is showing 3 red lights
Try this website
http://www.everything4360.com/Xbox360_3_red_light_fix.html :
Apr 10, 2009 | Microsoft Xbox 360 Pro System Console
No picture or sound and no red lights
make sure the switch at the back of xbox is on tv or hd, whatever you use.
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 will use sound but wont show picture?
The GPU chip has a bad contact underneath. We can fix this for you.
Dec 30, 2008 | Microsoft Xbox 360 Console
My xbox 360 has no picture or sound
Check your Monitor. if you are not getting the Red lights in front of the Xbox360 then nothing wrong with the wires.
you can try another Xbox360 cable goto you local store buy one, and test it, if the same result you can return the cable abit of a hassle though.
But usually when the cable are bad the red will flash in front of the Xbox, otherwise test the monitor or the TV with something else.
if all that checks out, then perhaps the XBOX360 is just plain dead.
they usually last about 4 years anyways. DVD drive goes bad. Video could be bad. hard to say
Dec 19, 2008 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
My xbox no show no picture
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
