Question about Porter Cable C2002 Wk Oil Free Umc Pancake Compressor w/13 Piece Accessory Kit
I purchased the Porter Cable 20 piece accessory kit part A00438, and no idea on how to assemble this. No instructions included either. This is the kit that allows to put airpressure in your car, bikes, tires of all kinds.
  • David Ford
    David Ford May 11, 2010
    I have checked 5 different sites and can find nothing, can you describe the kit to me and I will try and help. I think I already have an idea that it included some air fittings along with a tire chuck possibly a blow gun also but help me if this not correct. I will check a Porter Cable cataloog Monday and see if it is in there
  • 152 Answers
First get some teflon thread tape, for applying 2 or 3 tightly wrapped turns around the male threaded quick-disconnect adapters, threaded end on your air hose and compressor before installation.
Note: remember that the female quick-disconnect adapter is also a check valve that will only release air when a male quick-disconnect adapter is inserted, i.e. do not install a  male quick-disconnect adapter directly to an air compressor outlet.
Note 2:Always remember to wear approved eye protection when operating air tools.
Start by installing the female quick-disconnect adapters on a male threaded end of the air hose and on to the outlet port on the air compressor tighten the connections with two open end wrench's. Then install the male quick-disconnect adapters to the other end of the hose, blow-gun tool, and the air chuck tool, (tighten as described above). The other implements in the kit (wire brush attachment, inflation needle, etc...) can be threaded in to the outlet port of the blow-gun as needed.
The operation of connecting  quick-disconnects are as follows: Grasp the tool in one hand, and with the other hand grasp the air line near the end leaving the thumb and fore finger free to operate the spring loaded outer release cylinder on the female quick-disconnect by pulling back on it. With the cylinder pulled back, insert the male quick-disconnect adapter in to the female quick-disconnect adapter, then release the thumb and fore finger from the outter release cylinder, thus locking the two together. check to be sure the lock has engaged by lightly pulling at the tool. Reversing this process will disengage the tool from the air line.
Hope this helps Good luck
Posted on Feb 22, 2009
How do I over haul porter cable PN 100
Take 4 bolts off top of tool and tap on bench or piece of wood and the insides will pop out.
Oct 04, 2014 | Porter Cable Tools & Hardware - Others
Where do I find the wheel kit assembly instructions - I cannot find them in any of the books
You have an axle, some washers, the wheel/tire assembly and a cap for the axle. Slide the axle through the frame and out the other side. place a washer on each end and the place the tire/wheel on each end of the axle. Put a washer on each end of the axle and then hammer the cap on the end of the axle to secure the wheel in place.
Aug 27, 2011 | Porter Cable 4,500 Watt 9 Hp Portable...
Need a rod for an oil run porter cable air compressor model c3151
Ok, the post shows 2 model numbers, so I will provide links for both. Be sure to only pay attention to the model number you actually have.
For a model C3151, an oilless compressor, the only way to get the connecting rod is by buying a piston kit, there is no individual replacement. KK-4835 is the part number and it runs about 50.00.
It can be purchased here.
Now if you have a C3551, an oiled compressor, the entire Eccentric Rod Assembly will have to be replaced. The part number is Z-D22207 and it runs about 100.00.
I hope this helps.
Dec 04, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
My PC compressor buids 42 psi and continues to run without building more pressure or shutting off
Look for massive air leaks all around the machine including the safety 'blow-off' valve. The compressor diaphragm may have a hole in it. If this machine is new, return it to the dealer and get your money back or at least get it repaired under warranty. Good luck!
Apr 05, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Air leaks via the head so tank does not maintain pressure
The air leak you have described is probably from the unloader valve which may not be seating after it dumps cylinder pressure. If you can find a good manual for it, disassemble the unloader valve and check for contaminates or build up around the seat. The differential spring may have lost it's value also, in which case you will need to replace the unloader assembly.
Jan 20, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
I need operating instructions
Here is a direct link to your owners manual. You can print it if you want a hard copy or you can order one from porter cable.
Hope this helps.
Mar 09, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Replacement Bulb For Kawasaki 19.2 Flashlight
   May I suggest taking the unit to where you purchased it and see what they say? Alph of Spokane WA.
Oct 11, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Porter Cable C2002 Wk Oil Free Umc Pancake Compressor w/13 Piece Accessory Kit Logo
237 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
