Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
frogbite Posted on Mar 05, 2013
I am looking for a parts diagram for an A.O. Smith pool pump motor model sp3220z1be.
This is off of a Hayward Tristar 2HP pool pump. I am replacing the bearings and when I opened it there is a plastic piece that is not listed in the generic parts list for the other A.O. Smith motors. It looks like it is to prevent someone from poking their fingers into housing on the running motor. It is not a cooling fan and mounted directly to front of the housing inside the motor.
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on May 25, 2009
SOURCE: how do i tear down impellar housing on ao smith
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
jdn4
  • 100 Answers
  • Posted on Feb 14, 2010
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
Anonymous
  • 366 Answers
  • Posted on Feb 22, 2010
SOURCE: 1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Testimonial: "Great. Thanks for the quick feedback. I look forward to saving a few $'s this year operating my pool. Cheers!"
MOTORWIZJ
Jay Finke
  • 1397 Answers
  • Posted on Aug 03, 2010
SOURCE: Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Anonymous
  • 11 Answers
  • Posted on Mar 05, 2013
SOURCE: I am looking for a parts diagram for an A.O. Smith pool pump motor SP3220Z1BE.
The motor is made by A.O. Smith in Tippton, OH. You can try calling them, and with any luck you may get a kind soul that can get you a splsh sheild. It is probably not a part you can purchase from a distributor, but that is an option you can also pursue. Good luck.
1helpful
2answers
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
My hayward 2hp ao smith turns on then kicks gfi breaker after a couple seconds. after several tries it works ok.
I think you have a failed start capacitor. Have your motor looked at by your professional pool supply.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
