Question about Danze D500540BNT Brushed Nickel Fairmont?? Single Handle Pressure Balance
Cannot get the cap off the shower handle of a Danze fixture
How to you get the cap off the shower handle? It is a push in cap. There has to be a way to remove the cap in order to remove the rest of the fixture.
Did anyone have to drill the cap off and replace it with another one? Drilling it out seems to me the only way
    New Friend:
  • 92 Answers
Not familiar with that exact unit but alot of the caps unscrew or pop out when pried or you may have set screw on body
Posted on Feb 23, 2009
We were trying to stop a leak in a danze songle handle shower faucet now the hot water won't turn off whar do we do?
you need a new cartridge if its fairly new. if its an older faucet it will have to be replaced, usually the hot water side warps the fixture and it leaks there nothing you can do about it except to replace it.
Aug 28, 2017 | Danze Home
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
The Fairmont has no apparent way to remove the handle to permit replacement of the cartriodge. How?
they either have a small cap on front to pop off then screw under cap..or they have under or to side of handle a very tiny set screw recessed...it is a allen screw...loosen and pull out...
Mar 12, 2011 | Danze Sheridan Tub & Shower Faucet
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Want to increase water flow rate through Danze shower assembly
There is a flow regulator in the shower head. You have to remove the shower head and inside just down below the pipe threads, you will see the water saver. It can either be a white disk that can be screwed out or a black piece of plastic that just sits down in ther or a very small rubber washer. If it's the small rubber washer, you will need something pointy to remove it. I use a dental pic for them.
Mar 22, 2009 | Home
Danze D500540BNT Brushed Nickel single handle leaks
only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
Feb 23, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
Danze shower fixture issue
If it is a single handle there should be an access hole to the under side of the handle that will allow access to a allen style set screw, loosen it and the handle can be removed.
Feb 21, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
How to you get the cap off the shower handle/
try a magnet before drilling if it don't work drill a small hole do not push in to screw
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze D500540BNT Brushed Nickel Fairmont?? Single Handle Pressure Balance Logo
373 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Bill Boyd
Are you a Danze Home Expert? Answer questions, earn points and help others
