Question about Pinnacle Dazzle DVD Recorder
Dazzle dvd recorder
I have a dazzle dvd recorder when i set up to put images onto disc i get half way through setting up then get the message a problem caused the program to stop working correctly
  • 27 Answers
What is the exact version of your program Instant DVD recorder? what type of DVC device do you have?
what type of connections did you use S-video or the composite?
Posted on Mar 05, 2009
When i plug the dazzel dvd recorder into my laptop my tv screen fuzzes but when i unplug it stops
Hey there. There are a few things that inorder to help you answer your problem I need to know: 1. What are you trying to record from (DVD, Xbox, etc.)? 2. What T.V. are you using? 2. What is your set up for recording (what cords, where those cords connect to, and essentially how you are able to get the image onto your laptop)? Please message me back with this info and I will attempt to help you in anyway I can :)
Jul 27, 2010 | Pinnacle Dazzle DVD Recorder
I'm having trouble with settings, even with 'automatic' setting for quality, I can't record for longer than 93 minutes. Has anyone else ever experienced this?
Hi and welcome to Fixyah,
In total recording time the maximum in DVD blank disc
Automatic - 104 minutes
Good - 104 minutes
Better - 78 minutes
Best - 62 minutes
Disc image to Hardrive
Automatic - 189 minutes
Good - 189 minutes
Better - 142 minutes
Best - 113 minutes
Now it is depend on your footage on how long it is.
Jan 27, 2010 | Pinnacle Dazzle DVD Recorder
Can not set time of recording
Hi and welcome to Fixya,
When you cannot get into put the time for recording on step number 4 all you have to do is to go back to step number 1. Double click on Pinnacle Instant DVD Recorder and choose go direct to the advance mode and click next.
On Step number 1 click on the pull down arrow and choose for dazzle DVC 100. Go back to step number 4 and now put the total and valid time recording.
If there is no Dazzle device on step number 1 go ahead and disconnect your dazzle and connect to another usb port or much better if you connect that at the back of the computer.Try it again.
Jan 08, 2010 | Pinnacle Dazzle DVD Recorder
Trying to copy home videos onto dvd thru dazzle product connected between vhs player and my computer. Can witness video on computer monitor while recording and says copy is complete. But when I check dvd...
Open again your Intant DVD Recorder and then after that do the advance mode. Next on step number 1 click the full down arrowed and then choose your dazzle device. On step number 2 click on the full down arrow and choose your DVD writer. Make sure that you already inserted your DVD blank disc then hit prepared button message comes out just click okay.
Nov 17, 2009 | Pinnacle Dazzle DVD Recorder
Pinnace Instant DVD Recorder will not let me record more than 107 minutes even though I choose the lower resolution. Is there a way I can get all 120 minutes from my VHS camcorder onto DVD with Pinnacle?
The maximum number of minutes that IDVDR can hold is 103 mins only. You can put more than 107 mins if you used hardisk folder then you can used nero to burn it to your dvd disc.
Nov 15, 2009 | Pinnacle Dazzle DVD Recorder
I click on start recording, but it isn't recording
Make sure that the video image will showing to the preview screen of the computer and make sure that the a/v cable is properly connected. Did you already install the driver for your device? Open your IDVDR then choose advance mode, click on next. On step number 1 choose or click on pull down arrow and look for dazzle dvc 100 device. Next on step number make sure that you choose where to save the video. Hard disk folder or DVD disc. If DVD disc choose your DVD writer. Jump to step number and then choose the right time for recording. That's it you may now check and try to start recording your video.
Oct 26, 2009 | Pinnacle Dazzle DVD Recorder
Can not record dvd movie that is more than 103 minutes in length?
The solution is the quality settings on the DVD settings. On a 4.7Gb disk, 279 minutes at 24% quality, down to 70 minutes at best quality. Also, more will fit on the 8.5Gb DL disks. You can also use automatic quality, that will fit the video that you have compiled onto a disk, using the highest quality setting that will allow it to fit. An alternate method is to 'burn' to an image file on the HD, then use a program like 'DVDShrink' to fit on the disk.
Apr 13, 2009 | Pinnacle Dazzle DVD Recorder
Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
Dec 09, 2008 | Pinnacle Dazzle DVD Recorder
Dazzle installation won't work!!!!
What is the version of the your Instant DVD Recorder? If it is the older version please try to use download the latest version in the link below to install the program
For XP:
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Vista 32:
For Vista 64
Dec 07, 2008 | Pinnacle Dazzle DVD Recorder
Pinnacle Dazzle DVD Recorder Logo
103 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
