Question about Refrigerators
Neff fridge frezzer FD8107 K9625xogb/31 is available in stores ?
Bought 2001 integrated
2 Suggested Answers
SOURCE: anyone got instructions how to fit wooden kitchen
Not sure if it helps, but here are some details from a supplement to the instructions
Posted on Jan 02, 2010
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
FREZZERS WORKING BUT FRIDGE ISNT
if the frezzer is full of ice you have an automatic defrost problem if not you have a frezzer fan problem
Apr 17, 2009 | Refrigerators
I have a large Neff refrigerator with a small freezer compartment at the top (the model no is not on the booklet or the fridge) the freezer door is broken - can i get a replacement? thank you Paul...
Hello Paul,
Try looking on ebay for a second hand or spares repair model.
Also try some of the refurb places where the cosmetic returns get sent with minor damage or faulty components.
PS:any chance you have fitting instructions for an integrated K4664 model ?
Mine came with no instructions how to reverse the door and fit to the wooden kitchen doors so and cant find any on the Neff website.
Thanks
I
PS:
Mar 01, 2009 | Neff K4664 Top Freezer Refrigerator
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
