Question about Microsoft Computers & Internet
I have to give ppt presentation on effect of engineering on environment
  • Gerald Russell
    Gerald Russell May 11, 2010
    are you looking for guidance on ppt?
  • bsevinc May 11, 2010
    Ppt is a perfect tool for it. What can I do for you to help?
  • 407 Answers
You will find some templates here to get you
http://office.microsoft.com/en-us/templates/CT101172721033.aspx
Posted on May 22, 2009
Why is plastic bad for the environment?
Some of the harmful effects of plastics on our environment are :
1. Soil pollution-Plastic is a nonbiodegradable waste, it cannot be decomposed by the microorganisms present in the soil and hence cause soil pollution.
2. Air pollution- Burning of plastic materials releases many toxic and dangerous gasses like carbon monoxide, and cause extreme air pollution.
3. Dangerous for water organisms- Disposing plastics on water bodies can harm water living organisms. Also, they cover up the surface of the water and not allow sunlight and oxygen to enter on water which can cause ***** of many water organisms.
4. Water pollution- Plastic also cause water pollution as plastic materials cannot be decomposed by the microorganisms present in water.
Jan 04, 2017 | Green Living
Tip
How to use PPT supersede PDF for presentations
Managers and Engineers usually need to present something using PPT, but there are many files are designed as PDF format, so they just use PDF file for presentation by maximazing PDF format, Firstly it is not as vivid as PPT and secondly, if one page of PDF is too long, audience could not see the lower contents in one screen.
Actually, there exists an application named PDF to PowerPoint Converter by which you can convert PDF to PowerPoint for presentations. All the elements will be prefectly reserved. Here are the steps:
Step1: download the program and then install it.
Step2: Launch the program and input the file, or directly drag them into the panel.
Step3: Customize the path and then clike convert. work will be done in seconds.
Notes: You can batch,partial amd right-click convert PDF to PowerPoint, and it also supports encrypted PDF conversion.
on Mar 29, 2010 | Computers & Internet
How do I recover a corrupt PowerPoint file?
If there was such problem, the simplest decision is described here:
Method 1:
Move the PowerPoint to different location : this is first and very useful troubleshooting method to repair PPT problems . Copy presentation and paste it on other computer hard.
Method 2: Open presentation in MS word document:
If you have tried above method, but still facing same problem then try to open corrupt PowerPoint in MS Word. Follow this below steps:
•Open MS Word.
•Click on Open button of File menu.
•Select Files of type box and navigate to your corrupt file, Open it.
Method 3: Use Safe Mode
To see your presentation in safe mode, first of all you will have to run PowerPoint in safe mode. Follow these steps to do it...
•Click on Start button.
•Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
•Now press OK button.
•Restart your system, during restart press & hold F8 button to start window in safe mode.
•Open & see your presentation.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise, for example as it is described here:
https://social.technet.microsoft.com/Forums/en-US/50c99db5-9167-44fe-b625-e2682fa682ca/corrupt-powerpoint-file?forum=officeitprolegacy
And also there is a universal decision and "an edition choice" it watch it here:
Online PPT repair tool
Sep 10, 2015 | Microsoft PowerPoint for PC
Fix corrupt powerpoint file
Use PowerPoint Repair Toolbox is efficient PPTX corrupted repair solution for damaged presentations in corresponding format so you may open these documents anytime and regardless the reason of file damage.
For more: https://www.pptxrepairtoolbox.com/
Sep 06, 2015 | Microsoft PowerPoint for PC
Powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Jul 27, 2015 | Microsoft PowerPoint 2003 for PC
Who do you upload a ppt presentation
a PPT presentation is not a video. YpuTube is for video files. mp4 wav avi etc
Jul 15, 2013 | YouTube Videos
I have images in .ppt format that I would like to upload to facebook. Is this an acceptable format?
.ppt is the extension for PowerPoint presentations, so it's not really an image format. This is why you willnot be able to upload it on Facebook.
However exporting the images from the .ppt is very easy! Just follow these simple steps and you will have your images exported and ready to be uploaded.
To export your PowerPoint slides to other file types (BMP, WMF, JPG, PNG, etc)
  • Open your presentation and choose Save As from the File menu.
  • In the Save As Type dropdown listbox, choose the file type you want to save.
  • Give the file a name and click OK.
  • PowerPoint asks whether you want to export just the current slide or your entire presentation. The question is worded a little oddly, so read the message carefully before clicking Yes or No.
When you save the entire presentation rather than a single slide, it uses the name you give it, makes a folder of that name, then creates the exported files in that folder, giving them names like Slide1.jpg, Slide2.jpg and so on.
Large PPT to video
Regarding converting ppt to video, these are many free powerpoint to video converters at:
http://www.masternewmedia.org/convert-powerpoint-to-video-guide-to-the-best-free-services/
If you are not care much about the conversion effect, you can use these tools.
If you want to get the best conversion effect that convert your presentation with all the animation, music, and videos retained, please try Acoolsoft PPT to Video.
Apr 04, 2009 | E-Machines M6811 Notebook
Powerpoint 2003 needed, not ppt viewer
Unfortunately, you are going to need to purchase Power Point 2003.
You can still purchase Power Point 2003 from a number of sites like
Yahoo shopping, MSN shopping etc.
http://shopping.msn.com/results/presentation-software/bcatid5562/forsale?text=category:presentation-software&ptnrId=178&ptnrData=38570
Apr 09, 2008 | Microsoft Office Standard for PC
Computers & Internet Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
