Question about Apple iPhone Smartphone
When plugged into changing dock, iPhone says, "This accessory doesn't work with iPhone", but I've have used it to charge my iPhone countless times. It also won't charge using my computer or by plugging it directly into the wall without the dock. Please help
  • 53 Answers
Check the jack where it plugs in and then if theres any thing in there, get it out.
Posted on Feb 21, 2009
Iphone 5 does not charge, nor does music come through the speakers when connected to the Jensen 205i docking music system via 8 to 30 pin adapter.
Hello Karan,
Thanks for choosing a Fixya.
As far as i know & from experiance of using Apple Product since many years, some times some accessories does not supports & works very well with iPhone. If your iPhone is working fine with other accessories that mean original accessories came from Apple then there is nothing wrong with iPhone, so please try it with another system or try with another 30 pin Apple original dock adapter & i hope it will work like charm.
Thanks & Regards,
Chandrashekhar !!
Aug 20, 2013 | Jensen JIMS-205i Docking Digital Music...
Charger
My experience from working in an electronics retailer who sells many different brands and models of iPhone and iPod docks has shown me that these docks are not robust.
It's common for the dock connector on these devices to break and stop working. It's also possible that your dock is not compatible with that iPhone.
If your iPhone used to charge on the dock but no longer works, I would not be surprised if the dock connector is now broken.
If the item is still under warranty, I would advise either contacting the manufacturer or returning it to the retailer.
You might have to switch back to the original apple charger until then.
Jun 18, 2013 | Cell Phones
I bought gigaware docking speaker for iPod and it always charged my iPhone, but now all of a sudden it won't charge anymore It said something like accessory not compatible will not charge
sir you first clean your docking speaker and then charge it.. it will work fine. or other wise change your speaker there time is over.
Mar 29, 2012 | Apple Cell Phones
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
Ihome ip87 it wont turn on it only charge my itouch?
If unit is plugged in and doesn't respond, try resetting the unit by
following these steps:
a) remove iPhone/iPod from dock
b) unplug unit from power source
c) remove back up batteries
d) wait 1 hour, then resume use
Jun 03, 2011 | SDI iHome2Go (IH80B) (Black) Docking...
My iphone 3GS is not been charging when I dock in JBL On Time 200P and it used to charge just fine. This happened after I used in a travel a hotel iHome as my charging dock, and then a wall charger for...
It seems an issue of the dock connector of your Iphone, please check if there's no contact blocked or bended, if there's one or more contacts with these conditions, you may need to replace the dock connector of Iphone.
Feb 24, 2011 | JBL On Time Docking Station for Apple iPod...
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Ipod 4th gen "charging not supported"
It does that to my iPhone; if I want to charge I have to use a separate cable and run the audio into the aux. Defeats the whole purpose of a dock if you ask me, but I guess they never anticipated what they'd have to do to charge the new iPhone batteries back when they designed the pre-G3-phone docks.
May 25, 2009 | Buck Klipsch iGroove Docking Station,...
Getting error message software not compatible with IPod
This compatibility issue is caused by the same change with the Apple Dock Connecter introduced with the iPhone 3G. Inside the iPod / iPhone Dock Connecter are 30 metal pins. Previous iPods and iPhones allowed for charging either over pins reserved for the USB connection or pins reserved for the obsolete Firewire connection.
While Apple apparently announced this upcoming change to manufactures of “Made for iPod” accessories back in 2005, Apple only formerly discontinued Firewire charging support with the most recent iPods. New iPods and iPhones can only charge via the USB pin.
As such, there is no way that a software update can fix this issue in the future; this is truly a modification in iPod hardware.
Dec 22, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
Apple iPhone Smartphone Logo
70 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
