Question about Epson Office Equipment & Supplies
UNABLE TO USE #88 INK FOR MY EPSON STYLUS PRINTER.
HELLO, I HAVE AN EPSON CX7450, & I PURCHASED INK # 88 CARTRIGES, WHICH STATES THAT IT'S COMPATIBLE WITH MY PRINTER, YET IT IS NOT PRINTING. I HAD BEEN USING #69. I'VE TAKEN IT OUT & REPLACED IT SEVERAL TIMES. CAN YOU HELP?
  • Epson Master
  • 419 Answers
I don't know where you got your #88 cartridges from or who told you that they were compatible with your printer, but they were wrong.
The CX7450 will only work with the #69 type cartridges.
The cartridges themselves may look similar but the chip programming will be different for each.
Hope that helps.
Posted on Feb 21, 2009
  • Smilidon Dec 21, 2011
    Actually you are wrong thew printer manual and the sticker inside the printer as well as the info on the OEM box for Epson 88 cartridges all clearly state that the 88 series will work. And they do, but they are low yield so there is no real reason to use them.
How do I LOAD CARTRIDGES INTO MY EPSON STYLUS NX110 PRINTER
Follow the link below:
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Click "replace ink cartriges" on the left of the page
and then select "Remove and install Cartriges"
May 04, 2011 | Epson stylus nx110 All-In-One InkJet...
Hi there, Just changed all 4 ink cartriages on cx7450 and the ink light is still on, with the on light blinking thanks, rob
First push all the ink cartridges tide to the fram to assure that they are in the rigth position, then you have to alline them and it maby nessasary to clean the heads before printing.
Apr 10, 2011 | Epson Stylus cx7450 All-In-One InkJet...
The Epson Stylus 88 Ink Cartridges
Ink usage is directly proportional to the busyness of the document to be printer.
A document that uses 5% of the page (a standard business letter) will use significantly less ink that a page that uses on 60% and has images within it.
Don
Mar 09, 2010 | Epson Stylus cx7450 All-In-One InkJet...
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Incompatible cartridges
cartridges maybe bad. Take the cartridges out then put them back into the printer. Turn the printer on and off. you can also get the ink pad reset utility from epson.com if that does not work.
May 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
272 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
