Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven not working
My oven thaks a long time to light then takes forever to heat up
  • Anonymous Mar 18, 2014
    Takes forever to ignite
  • Kenmore Master
  • 3,361 Answers
Replace the glow bar ignitor.
Posted on Feb 21, 2009
My oven takes forever to pre-heat and sometimes not at all. Is my heating coil shot?
If your electric oven is taking too longto heat or just not heating up right,then check out this tip that will givemore detail about your problem.
Oven ProblemsElectric Oven is Heating Slowly or Poorly
heatman101
Apr 17, 2011 | Maytag Ovens
Oven is taking forever to get to the proper temperature.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 05, 2011 | Ovens
It takes forever to cook anything in the oven I set the temp. the buzzer goes off and I put in the dish in. but it takes too long to cook.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Jan 04, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Gas metal tube on bottom is noy staying lit. Takes forever to pre heat. It does ignite and gas does come out for a second then goes out.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 23, 2010 | Ovens
Maytag Gemini mgr6775 Lower oven takes FOREVER to preheat, but even when it says it is at 350, an independent oven thermometer says 310. It takes so long to bake anything.
Dear Scrapyourhea,
First ensure that your independent thermometer is working fine. It seems that there is problem with your heat mechanism. Normally this type of problems requires servicing....
Download the manual from given link and go through it. This will tell you the cause for the same.
http://www.retrevo.com/support/Maytag-MGR6751BDS-Ranges-manual/id/23649ci773/t/2/
Jun 07, 2010 | Ovens
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
128 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
