Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Lift-Master GDO goes up, not down
1/2 HP Lift-Master GDO. No recent gear replacement or adjustments. Door started to fail to go down. Adjusted down sensor to max, no effect. Electric eye operation is normal. No evidence of gear shavings inside, RPM sensor seems to be working correctly. (When I disconnected it, it failed differently)
Door will come up just fine once down. Even when I disconnected trolley from door, trolley only moves about 12 inches, then reverses. LED sensor flashes 4 times. Any hints?
  • 152 Answers
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Posted on Feb 22, 2009
My garage door does not want to close but it will open with no trouble I reset it but it still does the same thing the one I have is 1/2 HP model #139.54985 can you help me?
You need to check your sensors first. If they are lit and aligned, increase your down force. Have you recently had the springs adjusted or serviced by a garage door tech? If so, force probably needs to be adjusted and the tech failed to adjust it accordingly. If not, one of your sensors is probably misaligned which is usually the problem.
Mar 01, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
Needs proper adjusment procedures
Check if your garage door is properly balanced. Pull the red handle to release the door and manually open it. It should stay up when opened all the way. Next, pull the door down to waist level. It should stay there. If not, the lift springs need adjustment, and that may be why the opener keeps reversing.
May 06, 2009 | Office Equipment & Supplies
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Craftsman GDO, Model 139.53600. moves 4inches up/ down
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
442 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
