Question about Dishwashers
Water does not drain completely - Dishwashers
  • 544 Answers
thank you for using Fixya .com
here are some sample pictures of Dishwasher machine.
Indicated in this Photo you will see the parts of specially the motor and pipes.
please check and clean the tube directing to the drain hose maybe something are only stuck.
if you seen the thing please take it off....
let me know if any changes happens.
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. water does not drain completely - dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
  • Posted on Feb 21, 2009
      Brigadier General:
    • 6,966 Answers
    Hi and welcome to FixYa,
    If you could post back the exact model number, then a more detailed solution could be proposed. Most Gaggenau Dishwashers start with the letters DF followed by 6 numbers.
    Initially, try to check the drain area. Normally, access to the drain area would be through a kick panel. Check the filter, valve, sump/bowl, impeller, pump and drain hose (kinks). Doable though not that easy and very messy.
    Good luck and thank you for using FixYa.
      Genius:
    • 1,550 Answers
    Reset dishwasher
    Make sure dishwasher is empty of water.
    Turn off Dishwasher
    Turn back on and within first 3 seconds press black button 4 times
    Push door closed and let washer go through cycle
    Check the drain line is clean .
    Water does not completely drain from bottom of dishwasher when cycle has completed.
    May just need to take sump apart and clean or you need new drain pump
    Mar 23, 2015 | General Electric Dishwashers
    Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
    The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
    Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
    The water is no draining completely out of the dishwasher, its's a Whirlpool 980 Deries
    If you are handy what you will have to do is unclog it. DO NOT USE DRAIN CLEANER. Pull out the filters, clean out the **** and you are good to go. Once you are done with that run it a couple of times and you should be good.
    Oct 10, 2012 | Whirlpool Dishwashers
    Doesn't drain out all the way water stays in
    Hi
    Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
    Daniel
    Aug 30, 2011 | Maytag Dishwasher
    After wash complete unit will not drain complete, water remains in filter trap. this water will smell after a short time.
    Here is a tip that I wrote that will help you with your dishwasher not draining problem...
    Dishwasher Problems - Water will not drain out
    heatman101
    Sep 06, 2010 | Bosch Dishwashers
    Dishwasher will not go through complete cycle it will not take water away
    most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
    Jul 01, 2009 | Electrolux Dishwashers
    Water not draining completely from Dishwasher tub
    That usually happens because of a faulty water level sensor, check it out.
    May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
    Whirlpool dishwasher is not fully draining after cycle complete
    THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
    Apr 07, 2009 | Dishwashers
    Standing water in my kenmore dishwasher after complete cycle
    heatman101
    z
    Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Dishwashers Logo
    19 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
