Question about Zanussi TC7102W Electric Dryer
LG TD C70045E problem
The condenser drawer is empty of water but when trying to dry clothes the dryer stops after a minute and the lights say to empty water drawer!
  • 3 Answers
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Posted on Mar 04, 2009
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Water doesn't go to water tank. Any advice? thanks a lot Peter. LG DRYER TD-C70045E
Try unscrewing the water hoses and cleaning or replacing the filter screens where they screw into the unit and also the valves.
Aug 28, 2011 | LG Dryers
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
LG TD-C70045E Condensing Dryer does not heat up, how do I fix it? All other controlls work fine just no heat.
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Aug 17, 2008 | LG Dryers
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
Zanussi TC7102W Electric Dryer Logo
751 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
