Question about Akai CFTD2083 20 in. TV/VCR/DVD Combo
Vcr has a tape jammed in it
A vcr tape is jammed in the player. The tape doesn't play, however, the motor keeps trying to play it. You can hear the winding sound even when you are watching the tv. The eject will not work. When you go off tv the ony thing that shows is the dvd. If you hold the eject button in it keeps saying there's no tape in, but there is and it's spinning.
Open it and remove
Posted on Feb 21, 2009
I start to play a VCR tape and it just stops playing and the machine turns off. This doesn't happen with a DVD, however.
The VCR tape will turn off when spools are Jammed to prevent breakage of the tape. Take out the VCR cassette and put a thick pencil in the each sprocket hole and try winding in the right direction (which means when you manually wind the tape the other spool should unwind without resistance). If you feel resistance the sprockets are jamming. Knock the cassette on a hard surface without breaking it and usually it will free the jam. If does not help then carefully open the the cassette screw and re-position the sprockets.
Mar 29, 2015 | Televison & Video
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
201 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
