Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag Neptune MDG4000BWW GAS DRYER
I am hoping someone can help.  I am trying to purchase a dryer door complete with the gasket. The area where the gasket goes around has sprung for lack of a better description. Does someone know where to get one ?  I have googled until I am blind    Thanks a million
  • 333 Answers
In the state of New Jersey there is an appliance store called abbot appliance parts. Call with make, model #, and serial # and they will help you. The phone # is (732) 244-2040 and the web site is http://www.manta.com/coms2/dnbcompany_dqpq2f I hope this helps. Don,t forget to rate my answer. Thanks.
Posted on Feb 21, 2009
My Maytag Neptune dryer doesn't stop unless I open the dryer door.
You will be needing to replace the timer assembly, which is the part that has all the wires attached and is found inside the top of the machine. It is what the dial is fastened to.
Be blessed.
Jan 08, 2014 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
Grinding noise.
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #14 on the drawing)
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDG5500AWW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=RESIDENTIAL-DRYER&diagramPageId=00006&componentDescription=TUMBLER&documentId=M0608072&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag won't dry on any cycle
if you have gone that far you have it fixed
since you diagnosed that there was flame you can fix this really easily
unplug the unit
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083&diagram_id=678789#d678789
look for the two parts 7 and 8
those are going bad and will need to be replaced
hope this helps
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
192 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
