Plate that dvd sits on while inserted into dvd wrter itself is stuck, how do I get it to work again? JZ
    Scholar:
  • 164 Answers
Thayt may take some work.
You need to remove the Burner and open it and then free yo the disk.
It sounds like you use it allot and it may be that the bearings are bad and it may not work.
replacement is called for.
Posted on Feb 21, 2009
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
My LG blu ray 3-D dvd player just stopped working. all it says is boot. I unpluged it but still just says boot. It was working fine. Now it wont turn on at all just says boot, its said boot for the pa
My LG 670 also said 'boot' after a upgrade attempt and appeared stuck there. I searched LG support for a factory reset option, which is: Disconnect the LG power cable from the wall / power stripHold down the power button the front of the player for 30 secondsRe-insert the power cordTurn the player back on. Note: my player showed 'boot' again for a few minutes, then shut off. When I turned it on again, it went through the normal power up cycle, then shut itself off (weird). I turned it on again. So far, so good.
Apr 24, 2012 | LG BX580 Blu-ray 3D Player
I need to remove the dvd-write/cd-wrter combo dive but it has some blue clips hold the drive. Seem I have to break the clips. Will I have problem if they are broken. Thanks for anyone'e help.
DONT BREAK....
it's clip on...to hold the drive in the slot....but you may find some screws on the side of the DVD / cd drive which is held to the case of the PC... just remove the screws and remove all the cables and just pull it out....
Apr 28, 2011 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Will not open door to insert DVD. What can I try?
remove the top cover and look at the side of the tray.there is a small motor and belt that drives the tray.the belt is probably pear shaped from sitting so long. give it a gentle push and it will probably open.some are gear driven and the motor could have a flat spot.in any event,push the tray gently and it will most likely open.
Apr 13, 2010 | Memorex MVD2022 DVD Player
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
DVD Drive will not open, has DVD stuck in it
There should be a small hole by the tray. insert a paper clip here and the drive will open manually
Dec 10, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Nov 11, 2008 | Rosen CV7080D Portable DVD Player
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
