Question about Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
  • 22 Answers
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Posted on Sep 08, 2009
What does EE mean under the Systolic reading on a Marshall tm91 Oscillometric ??
This is an error state.. Probably too noisy kortoff sounds to register if too high for cheap home units.. Probably need to test with cuff and stethoscope.
Sep 20, 2014 | Health & Beauty
What does ee mean on the omron blood pressure monitor/HEM-731C?
is it a 780 or a 731? found manual for 780; http://omronhealthcare.com/wp-content/uploads/hem-780-instruction-manual.pdf nothing on 731. Try removing the battery for 10 min to reset all. May be time to replace.
May 02, 2014 | Omron HEM 780 Automatic Blood Pressure...
After the cuff was on and I pushed start the monitor pumped up to approx 155 then released and began to pump again until it reached (systolic) then slowing released the pressure. Then the reading showed ...
I think you did not put on the manchet correct. Read the manual and do exact what is in the manual. The sensor should be over the main artery and nor somewhere around the arm.
Feb 18, 2014 | One Touch A & D One-touch Blood Pressure...
Directions to use Model 83 Walgreens digital blood pressure monitor
The Walgreens Model 83 was not made by Homedics, but in 1999 by Omron at http://www.omronhealthcare.com
I called the 800-634-4350 number on the back of the device, and got someone who immediately emailed me the instruction manual! Now that is unusually good service for this day-and-age.
I would have posted the PDF here, but this site doesn't allow PDF uploads.
Feb 09, 2012 | Walgreens Blood Pressure And Pulse Monitor
Lately when trying to get blood pressure "EE"
The EE symbol can mean one of three things: Excessive low blood pressure, improperly placed cuff or movement of the arm during the measurement.
Hope this helps solve the problem. If it continues, contact HoMedics Customer Service @ 800-466-3342
Mar 22, 2011 | Homedics Automatic Arm Blood Pressure...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Reading EE
The cuff sensor must be placed directly over the vain. This takes practice.
Feb 01, 2009 | Homedics Deluxe Automatic Arm Blood...
Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17 Logo
607 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
