Question about Epson Stylus C43SX InkJet Printer
C43 stylus does'nt print
Red and green lights are on but printer does'nt print at all,as if not detected by my computer
  • rmg028 Feb 21, 2009
    red and green light are lighted permanently,and my computer says no printer is attached to my computer
  • Anonymous Apr 16, 2009
    my computer say d comunication with d printer is error
  • 353 Answers
What rotorcrafts omits to say, is that this has occurred because the waste ink protection counter was warning you that your waste ink pads are saturated with ink and should be replaced. If you don't do this, eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on May 11, 2009
  • raj6jan Jan 28, 2011
    hey can u help me changing it
    Guru:
  • 302 Answers
Try the following it may help.Please download the following software.and install it.
http://www.ssclg.com/download/sscserve.exe
Now select the appropriate printer model in the configurations tab.Now close this window and a small printer icon will appear in the taskbar.Right click on it and go to Protection counter and select "Clear counter overflow".
just do this and you printer will work fine again.
Thankyou,
Mohsin Idrees Khan.
Posted on Apr 08, 2009
Epson stylus cx4600, not working
the printer wont work it will copy but not print anything off computer
Feb 01, 2010 | Epson Stylus CX4600 All-In-One InkJet...
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
Epson stylus 88+ drivers for windows NT
go to google search .while searching type the ur os name and and printer like(driver for printer name and windows nt os)ther u can find ur drivers
Feb 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer wont work just feeds paper straight through
First try reinstalling driver software on your computer.
Either use printer CD or download from website:
Epson Driver Download
Epson America, Inc. - Support
If problem persists after downloading software, then that means that ink had clogged the printheads after drying up on old installed cartridges.
In that case either order a new printhead from Epson, or replace the printer.
Feb 03, 2009 | Epson Stylus C46 InkJet Printer
Green & red lights flashing alternativly
Hi
If pads need to be replaced, better get a new printer instead since if you are going to wash pads there is no guarantee that printer will work. get a new one, call epson at 562-276-1300. you can get a better deal from them.
Hope this help
Jan 11, 2009 | Epson Stylus C44UX InkJet Printer
Printer problam
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them
for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44 etc service manuals, as far as ink pad replacement goes, they are the same.
Sep 24, 2008 | Epson Stylus C43SX InkJet Printer
My printer
sounds quite compelling
Mar 08, 2008 | Epson Stylus C60 InkJet Printer
Epsom stylus c60
For the record, problem solved!
Mar 05, 2008 | Epson Stylus C60 InkJet Printer
Epson stylus c60
hmmm..is the cable from the printer to computer happy? unplug it, and see if it shows on the computer screen, when you plug it back in.
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
210 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
