Question about Whirlpool Duet GHW9150P Front Load Washer
Timer display keeps flashing the minutes
I can add or delete minutes, it will not reset I keep pressing the 3 second button. nothing I need help
  • ramiro182 Feb 21, 2009
    now it flashes F H
    now it flashes FH
  • 837 Answers
Try unplugging the dishwasher for at least 15 minutes .. Let me know if you still have problems after plugging it back in .. Crayz
Posted on Feb 21, 2009
Arietta Range Hood Setting clock
Clock programming
t The clock can be reprogrammed at any time except
during an active timed function.
t The clock can be displayed in a twelve hour form at and
valid clock times are from 1:00 to 12:59.
t The clock can be reprogrammed pressing the " Timer "
button for 3 seconds, and after, the clock can be
adjusted with the "+" and "-" buttons.
t The user can have minute increments / decrements of 1
minute, but if the user keep pressing the "+" / "-" buttons
for more than 1 second, the increments / decrements will
be of 5 minutes.
During this option the control will round to the nearest 5
minutes.
t The user can finish on reprogramming the clock pressing
the "Timer " button.
t After 1 minute of no button pressed the control will
accept the programmed clock time and will add one
minute to the set clock.
Jan 29, 2012 | Kitchen Ranges
Arietta range hood how do i set the clock
Clock programming
* The clock can be reprogrammed at any time except
* The clock can be displayed in a twelve hour form at and
* The clock can be reprogrammed pressing the " Timer "
* The user can have minute increments / decrements of 1
be of 5 minutes.
minutes.
* The user can finish on reprogramming the clock pressing
* After 1 minute of no button pressed the control will
How do I program a Noma N1506 timer?
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
How do I reset the oil service counter
1. Switch ignition OFF.
2. Press and hold button "A" - fig. 1 or fig. 2.
3. Turn ignition key to position "I".
4. After 5 seconds the words "OIL SERVICE" or "INSPECTION" are shown together with the message "reset" or "re".
5. Release button "A". Press and hold button "A". After a futher 5 seconds the message "reset" starts to flash.
6. Release button "A". Press and release button "A" again.
7. The new service interval is now displayed.
8. Press and release button "A". The message "END SIA" is now displayed.
8. Switch ignition OFF.
Fig.1
Fig.2
Aug 27, 2010 | 2004 BMW 3 Series
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
Casio g-shock watch
http://world.casio.com/wat/download/en/manual/
try for the manual from here.
riz.
Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Whirlpool Duet GHW9150P Front Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
prem mathew
