Question about Whirlpool GU2400XTP Built-in Dishwasher
The clean button keeps blinking, will not go off and i cant restart to wash. i hit the heat dry button for six seconds and it was unlocked but i cant get the washer to restart.
  • 188 Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 21, 2009
All buttons are working on my washer and when i start it it sounds like it going to run but the wash cycle doesn't kick on. i did reset the buttons what could this be
Posted on Nov 07, 2009
  • 837 Answers
Try unplugging the dishwasher for at least 15 minutes .. Let me know if you still have problems after plugging it back in .. Crayz
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Clean button will not go off
Alternate solution: Within 6 seconds, alternately press "heated dry" then "normal" buttons. Wait for all lights to come on and for the diswasher to finish washing the load.
Jun 19, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
278 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
