Question about Microsoft Windows XP Professional for PC
System not booting harddisk connected in master &cd drive conected in slave os win xp sp2 wts the main problem
    Problem Solver:
  • 7 Answers
Plz set ur hardisk as the 1st boot device in the bios setup. u can enter the bios setup by pressing the del or f2 key when u power on the mission
Posted on Feb 24, 2009
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
PC Will Not Boot
hi there
i do agree with you about the ribbon cables please make verry sure that they are connected right ie set as master or slave also make sure that the ribbon is tight and then make sure that you boot into bios and see if the computer can recognize the drive and see if it is set to master or slave and see if there are any jumpers on the hard drive that match with what bios is telling you cause if the bios is set to master and you have the jumper set to slave it will not work
Mar 05, 2009 | Gateway Computers & Internet
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
PATA Harddisk connection
Hi Murtazasoni, if you have the manual for K8V-MX motherboard you shouldn't have any troubles. You can download it from this link, Win XP; http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
The IDE data ribbon only connects to the PATA drive & motherboard in one direction. Please see the top of page 1-22 for instructions. Most data ribbons for IDE drives have three connectors. The connector farthest from the other two connectors (Two connectors very close to each other), is plugged directly to the motherboard as shown & explained on the top of page 1-22.
If you are only connecting 1 PATA drive to the data ribbon, connect it to the last connector on the ribbon, leaving the next connector for another PATA drive.
Setting the jumper on a PATA drive. Every hard disk drive has a large white sticker on it. This sticker includes information about the drive. Things like the model number of the drive. There is also information regarding how the drive is to be set. Example: if the drive is to be the only drive in the system its jumper should be set to (Master drive only). If there is another PATA drive in the system connected to the same ribbon cable than change the jumper on the drive to, (Master with a Slave). The second PATA drive's jumper must be set to, (Slave). Connect the power cable to the PATA drive ['s]. Re-check all connectors (internally) before closing the case. Boot the system & press the Delete key on the keyboard every two seconds until the main bios menu opens. Open your manual to the top of page 2-7. Here you'll learn how to move about while in the bios. At the main menu you should see your PATA drive. Listed to the right of Primary IDE Master you should see the model number of the PATA drive listed. If not than the drive was not connected correctly. Shut down the system. Unplug the power cord from the system, open the case & re-check the data ribbon for correct orientation, solid insertion & solid insertion of power cable to drive. Connect the power cord to the system & boot to the bios again. Once the drive is listed go to the title Boot, section 2.6, page 2-27 & follow the instruction through to page 2-28.
Open your CD-ROM drive & load your windows CD, close the CD drawl.
Save bios changes & exit. The system will auto restart.
The system should start loading windows if you set the boot device correctly as shown in the manual.
If you find this too difficult to follow, suggest you ask a friend with more PC knowledge for assistance.
Mike
Jul 14, 2008 | ASUS K8V-MX Motherboard
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
MOTHERBOARD PROBLEM
Check the jumpers of harddrives it should be MASTER and the two CD drive are set to SLAVE... Then cable 1 contains one master (winxp loader) and one slave (combo). The second cable contains one master (new 80gb) and one slave (CD-ROM).
Boot in safe mode to repair itself... Press F5 for that before it reads the OS
Good luck... Fixya
Feb 02, 2008 | HP (D7580-60003) Motherboard
Installing Hard Drive on Dell 8300
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
