Question about Amana ARB2217CSR Bottom Freezer Refrigerator
Amana ARB2217CSR freezer not working right
The freezer had a build up of frsot/ice on the read of the compartment and frozen articles were obviously warming up although ice was OK? I suspect compressor failure on this six year old unit.
  • Amana Master
  • 3,361 Answers
You have defrost control parts failure.
Either defrost timer, defrost thermostat or defrost heater.
Posted on Feb 21, 2009
Lite bulb in freezer not working, put a new bulb in still not working
Unplug it.
There is usually a switch that gets frozen in the closed (door) position.
Try looking in the freezer, front and center, ceiling area.
If the switch moves easily, then it could be the socket.
If it is iced up, wipe it with a warm wet cloth in the same direction that the door opens and closes to get it to spring back.
Plug it back in.
If that doesn't help post a model # and I'll continue the walk through.
Feb 23, 2015 | Amana ARB2217CSR Bottom Freezer...
Freezer vents full of frost.around every two months. Top refrigerator warm up. I resolve by removing all frost and ice from the freezer vents to clear cold path and get it to work. Possible problems...
First try melting the ice with hair dryer. See drain tube going to pan under frig? It can get clogged/frozen with ice. I cleaned mine with very warm water shot out of a water pik. Or u can hair dryer it, then pour warm water on the little pan that holds the drain tube. Be sure that tube is clear for draining.Otherwise, more ice at vents.
Aug 22, 2011 | Amana ARB2217CSR Bottom Freezer...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Amana refrigerator, bottom freezer. Back keeps icing up. I have unplugged and thawed it twice, within 2 weeks it is frozen again and freezer warm
This is a defrost problem most likely caused by a defective defrost thermostat. It is located in the freezer compartment behind back wall on top right hand side of coils and usually has a brown and an orange wire connecting to it. It should have continuity when checking with a volt/ohm meter when it is frozen and read open when it is warm.
I have seen many of the newer electronic temperature model bottom mounts with defective control boards as well that cause the fridge to skip the defrost cycle.
Jun 14, 2010 | Amana Refrigerators
Freezer does not defrost it is amana modelDRB2201CW, ICE BUILD UP IN ONE WEEK AND NO COLD AIR FOR FRIDGE AREA BUT FREEZER PART IS WORKING, THOUGH NOT AS IT SHOULD
Youu most likely have a defective defrost thermostat in this model. It is located behind the cover in the freezer compartment and is a small round device with two wires attatched to it. It is attatched to the freezer coils on the top right hand side. It ususally has an orange and a brown wire connected to it.
Part number is 12001937 and should cost about 23.00. This part should read "closed" on a continuity check when it is frozen, and opens when it is warmed above about 55 degrees.
The idea behind this part is to shut off the heater during defrost should it get too warm in the evaporator area, however when they fail it does not allow the heater to come on.
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
No air flow in fridge compartment,rfeezer working but not as well as normal
you may have ice build up at the freezer section. kindly look at the back side of the freezer if you have ice build up.
if you do then you have problem with defrosting.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Amana 22.6 cu. ft. Side-By-Side...
No cooling in refrig, botton freezer forming too much ice
let me know I can help you get it going again..
Sep 01, 2008 | Amana Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana ARB2217CSR Bottom Freezer Refrigerator Logo
326 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
