Question about MSI 915G Combo-FR Motherboard
Dears - I am instaling with 915G combo, HDD-ID IS DETECTING AS SLAVE BUT NOT AS MASTER, KINDLY HELP
  • 67 Answers
Did you look at the jumper settings at the back of the hard drive. It should show you how to set the jumpers for slave or master or cable select. Once you set your jumpers it should work.
Posted on Feb 21, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Not detecting hard disk. when i plug my IDE hard drive the red and yellow LED in my computer always light
Be sure about Master-slave pin jumper. If it is sharing same cable from main HDD please set it as slave, but if alone, then set is as master or Cable Select.
Dont forget to rate!
Jun 17, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Slave is ok but master freezes...
you can install even if it is a slave disk. also you can try setting the jumpers to master mode, check the sides of the hdd, it has a jumper setting and set it to master, using the shorting pin, just plug it out and connect it to the right setting
Jun 03, 2010 | Seagate Notebook Hard Drives: 40GB...
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
May 16, 2009 | ASUS Computers & Internet
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
I have a problem .i.e my seagate barracuda 160gb HDD is not detecting in bios .it is a new HDD
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
Nov 14, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
DVD Writer not working
Make sure the jumper on the back of the new drive is set the same as the old one. EXAMPLE: Slave, Master, Cable Select
Jun 13, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
MSI 915G Combo-FR Motherboard Logo
75 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
