Question about Bosch SHU5316UC Dishwasher
How to use Bosch S510
I was give an old S510, what id the difference between the green cycle and the brown cycle?
I have an older hunter Seville 3 speed motor and need the proper positions for the green brown and gray to the ze 268s2 switch
Try this; 1 - green 2 - gray 3 - brown L - black
Is the switch you have from Hunter or did you buy it off a rack somewhere? The switch could look the same on the outside and be different on the inside. fanman9952@aol.com
Jan 28, 2015 | Hunter Dryers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I am trying to install the new tx900ts in my house and i do not understand the wiring on it i have a old trane thermastat that has different wiring codes
PLEASE GIVE ME A RATING AND VOTE YOU NEED TO FIGURE YOUR WIRES WRITE IT ALL DOWN AT UNITS AND THE OLD STAT
common is different by installer so you gotta look at the units or you will blow out your transformer this wire will be blue or brown
24v always red
compressor always yellow
fan always green
reversing valve always orange
heat w1 always white
emergency heat will be either brown or black dependinting on installer if its a heat pump this it what you have but if its a gas system its much easier
red- 24 volt with a jumper already on the new stat
white- heat w terminal
yellow- cool y termina
fan green- g terminal
and common is optional with batteries so its not needed
if you need further help email pendletonheatandair@hotmail.com
Sep 20, 2010 | Heating & Cooling
Replaced fan motor for outdoor ac unit old fan has blue,black,red,and green wires new fan has brown,black,yellow,brown/white and green what goes where
Hi, the 2 - brown wires are for there own run capacitor they should have sold you. One of the browns will have a white stripe. The new cap has only 2- terminals and you put a brown on each side. The black and yellow wires are both hot which 1- will go to 120 volts on the load or out side of the contactor, and the same with yellow, 120 volts. This gives you 220 volts to run the motor. Look on the new motor and you will have a diagram or on a paper that comes in the box. The old motor used the dual cap to run the compressor to. The green is just a ground wire. Screw it to any metal part or screw. You should be able to put the black and yellow hot wires where the old black, red, or blue were as long as they are 120 volts which I am sure they are. Get a cheap tester when you go get the cap for the new motor, and check the old blk, red, and blue terminals to ground and you should have 120 volts on at least 2 of them. Put the new yellow to 1 and black to another, browns to the new cap and your off and running. Keep me posted. I do this everyday. Please be kind when rating me, thank you.
Shastalaker7
A/C, Heating Contractor
Jul 09, 2010 | Heating & Cooling
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch dishwasher not 'steaming' plates dry
first check to make sure you don't have a air dry option.then look at the thermostat then heater.
Oct 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My trusty Bosch s510 Dishwasher which has been going strong for about 17 years (at least) has just decided not to empty itself. I noticed the bottom was full of water after a wash. I emptied all the water...
Same problem, so went out and bought a new bosch. Problem with the S510 was cured by lubricating the pump out motor bearings with a squirt of WD 40. If you don't know which pump, follow outlet hose to pump outlet.
Les
Aug 15, 2008 | Bosch Dishwashers
Installation guide - bosch hbn131250b
1. The screws seem to need a small hex screwdriver, but I managed to get my normal electrical screwdriver to fit - they are not too tight.
2. The wiring is straightforward - there is an earth position with no wire from the oven attached, marked with the standard earth sign, that should connect to your yellow/green wire. The other two connectors have either a blue (neutral) or a brown (live) wire attached to them - they should connect to your black (neutral in old money) or red (live) wires
Jan 27, 2008 | Ovens
How to program my new Keyboard cordless desktop S510
When I bought my s510 recently I couldn't use the function keys even with the software that came with the keyboard and mouse.
I had to actually download new logitech software for the s510 which allowed me to use the function/extra keys.
Navigate to:
http://www.logitech.com/index.cfm/keyboards/keyboard_mice_combos/devices/145&cl=US,EN
On the right hand side of the screen you will see 'Support Center' below it click 'Downloads,'
From there you can choose your OS w98 and language and download the software you need to get your keyboard working the way it should.
Oct 12, 2007 | Logitech Computers & Internet
Bosch SHU5316UC Dishwasher Logo
467 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
