Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My mac book which I have had for more than a year all of a sudden is unable to sustain its wireless internet connection. It begins at 100% and then slowly decreases to 0. Any thoughts? Thanks
  • JG1977
    JG1977 May 11, 2010
    check the transmitter setting in utilities/airport utility.
  • 55 Answers
Airport cards do fail, it sounds like yours has, they are not that expensive now, so having it changed won't cost an arm and a leg.
Posted on Feb 22, 2009
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
MSI U120 Netbook Internet Connection Problem? After months of working at an adequate level, the netbook stopped detecting wireless networks. What happened? There's nothing wrong with the internet. The...
At times, a netbook or notebook can create multiple duplicate links to the same network. Each one will diminish the strength of the connection by a little bit and you should clean them out so that there is only one.
Also, it makes sense to use the MAC address on the server side, such that only a netbook with your unique MAC address can connect to the wireless connection. It saves energy/strength if that is your only real security stopper, since like fingerprints, there are no such things as duplicate MAC addresses.
Try making those changes you might just find a cleaner, stronger connection to your WiFi at home.
Good Luck,
-a.
Jul 24, 2010 | MSI U120-024US Notebook
Apple USB Ethernet suddenly not functional with mac book air
I've run into a similar problem myself. The problem could be that there is another device in the area using the same frequency and is causing interference. Try changing the frequency on your adapter. If you've recently added a wireless device and you can't change the frequency on your adapter try changing the frequency on the new device or turning it off to test if it's the problem.
It's possible someone else in the area has added a device that's causing the problem look around for new wireless devices or antenna in the area.
May 27, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Mac notebook unable to connect to the internet wirelessly
go to network setting then assist me , select default location after completing it . go to advance setting then check dns server and add the server ip adress in it save the settings check it is working. rate if helpfull
Apr 15, 2009 | Apple aluminum 13-inch MacBook laptop-...
My internet is unusually slow, and unresponsive.
well it sounds like you need either to reset your wireless router(little blue utton on the back of the router) or you need to clear your safari history/cashe.
good luck
ryan
Mar 18, 2009 | Apple MacBook Mac Notebook
Can't find wireless Signal
Make sure her router is configured to broadcast the SSID as that can either be disabled or enabled. Once thats enabled and you still cant see it try and set it to different wireless channels and change the wireless network mode to 'mix"
Jan 03, 2009 | HP Pavilion dv6000z Notebook
Reliance NetConnect
I also purchased CDMA 1x but i have good speed. change modem setting put "DNS" 8.8.8.8 & "Alternate DNS" 8.8.4.4 and type in "Static Ip address" 8.8.8.8.now connect internet check speed.it's not high speed we are satisfied.bye.
Nov 15, 2007 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
37 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
