Question about HTC Advantage X7500 Smartphone
Unlocking protected password dopod U1000 (HTC advantage X7500)
My phone fell down, then I have to soft reset the phone, the screen comes to input password, I type the correct password, but it is said you have type incorrect password !?!? the hint showed up ... I entered the right password, but keep saying type incorrect password. now the device response time gets longer. how to clear the memory then ? Based on page 92 manual user book ? I do not want to hard reset as I do not have back up, and many data inside will be lost.
please help .... I really need help how to solve this password trouble ? as I always type the right password. i have been trying many times soft reset, it does not help. keep saying incorrect password.
  • Anonymous Apr 01, 2009
    the same problem, ibrahim@adv-con.net
  • harmeetsingh Nov 23, 2009
    i have htc x7500 / dopod u1000 windows phone & i am not able to unlock that device. i am entering the same password that i have saved in it but an error INVALID PASSWORD appearing so please tell me how to reset the password.
    Problem Solver:
  • 4 Answers
Pak Agus, You was try to ask puk pin to your provider ? Please, you try to call your provider to ask puk pin.
Regard, Ngajio
Posted on Jun 03, 2009
How to unlock HTC advantage 7500, forgotten the password
You may try default phone and security code to remove it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 19, 2010 | HTC Advantage X7500 Smartphone
I fogot my password...how do i unlock my phone...i
I hope you have your contacts backed up because there is no way to unlock it without performing a Hard Reset. First hold down both soft keys and the soft reset hole at the bottom by the memory card slot simultaneously. The soft keys are the 2 dots to the left and right of the D-pad. If you do it correctly, on-screen prompts will appear on a white screen, just follow it from there!
Feb 18, 2010 | HTC PPC-6800 Smartphone
My HTC Touch phone screen is not working and my phone is protected by a a screen password that means i cannot access my contacts or anything in my phone
You will have to try and remember your password, otherwise you will have to do a hard reset. turn off phone, remove memory card, turn on phone by holding down power/green/red all at the same time, this will loose all your contacts and settings and resor back to new.
Dan
Dec 08, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC X7500 Failure
I am having the same problem perhaps. the screen turned to multiple colors in lines- red, green, blue and white. I cannot even reset and do something.
Sep 15, 2009 | HTC Advantage X7500 Smartphone
Screen stop run, just show windows mobile.
I got that solution for this problem. My HTC is normal again now...
Regard,
Ngajio
Jun 02, 2009 | HTC Advantage X7500 Smartphone
How do I reset my Advantage X7500 password?
To do a hard reset (everything erased off the device) just press and hold the volume down (on the upper left) while pressing the small reset button on the back of the device. This will bring it back to factory details, but you will lose everything that isn't on the hard drive.
Caid.
Dec 02, 2008 | HTC Advantage X7500 Smartphone
Reloading tom tom on to htc advantage x7500
I recommend going to xda-forums and looking around there. I know you can find it there, I just don't know exactly where it is. There is a special forum just for the x7500 there, it's listed as the Athena.
Google xda-developers to begin your search, and good hope to you on that.
Caid.
Nov 13, 2008 | HTC Advantage X7500 Smartphone
HTC Advantage keeps switching off during a call!!!
My phone's screen turns off while I'm on the phone if I don't put in any input. That doesn't turn off the call... however, I've noticed bugs on my phone as well. Perhaps you could tell me which OS you're running on it, and which programs you've installed since you had the phone. If it's done this since day 1, it may be one problem, if it's done it only recently, it may be another.
I would recommend going into your settings, turning off all auto sleeps as well as disabling the auto shut off blacklight after a certain time. Set all settings to make sure the phone only sleeps when you tell it to (aka pressing the sleep button).
If that doesn't work, try deleting some appllications you installed (in your settings, remove programs.) Start with ones which are only related to your phone's phone.... get it? ;)
If that doesn't work, there are other solutions but they involve more work (ie hard reset). READ CAREFULLY HERE Just as a note, to do a hard reset (erase everything and start again) press and hold the volume down button and then press the reset button on the back while still holding the volume down.
WARNING  this will delete all personal information, programs that you installed yourself, and contact information.  ALSO Anything on the Microdrive (8GB) will not be erased, ONLY the things on the device itself.
Good luck, I hope that helps you. If not, well, post some more details and I'll try to help.
Caid.
Sep 24, 2008 | HTC Advantage X7500 Smartphone
Lock code
HTC X7500/7501-(ATHENA/ADVANTAGE/Dopod U1000/T.Mobile AMEO)
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.)
or try with this link...
http://www.efsoft.it/resetdev.htm
Jun 09, 2008 | HTC Advantage X7500 Smartphone
HTC Advantage X7500 Smartphone Logo
587 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
