Question about Chaintech GSA73GT NVIDIA GeForce 7300GT 256MB (256 MB) AGP Graphic Card
Problem troubleshooting probleme affichage probleme installation probleme demarrage
  • 1,602 Answers
GO TO CONTROL PANEL, OPEN PERSONALIZATION, OPEN DISPLAY SETTINGS, FIND ADVANCED SETTING AND OPEN THAT FOLDER, SHOULD HAVE TROUBLESHOOTING IN THE SECTION
ROD
Posted on Feb 28, 2009
My Acer Aspire 5349-2592 network adapter keeps having to be reset by troubleshooting, but it doesn't always solve the problem. Is there a driver I can replace it with?
Hi there
I assume that you are using the ethernet connection and have proved that there are no problems with the cable, wall socket, router, network generally,etc.
If so the first thing I would do is to go to the link below, select your product from the lists given and check the driver you have installed is the correct one for your operating system, as there is only one listed for your machine. The simplest way may be to simply download this driver and install it to see if this cures your problem.
Drivers and Manuals
Alternatively if you are using a wireless access point you will need to check which wireless adaptor you have and then down load the appropriate driver and install it.
If these both fail to correct the problem, and all the rest of the network components are fine, you may be looking at a gradual deterioration of the LAN hardware, in whci case you should consider repair, or just to check, obtain a USB wireless LAN adaptor and driver and try that. They are relatively cheap, and if the problems continue even after that then the cause must be outside of your laptop and its hardware.
Hope this helps
Cheers
Nov 09, 2014 | Acer Aspire 5349-2592 Laptop Celeron...
Toshiba l20-267
Find out if you have more than one monitor connection on your computer.
Look at the back of your computer for two Video Graphics Array (VGA) connectors or Digital Visual Interface (DVI) and VGA.
If there is a VGA unused connector, plug in the other monitor there.
Purchase and install a video card if you don't have a second connector available. Make sure
Windows XP or newer software installed on your computer can support a new video card and dual-view features.
Any Nvidia GeForce VGA DVI SVID card is good if you have PCI slot available (or ATI Radeon DVI VGA S video card for AGP slot).
Install the video card into the slot on your computer and the driver provided with the card. If you don't know much aboutcomputers, find assistance from a local computer retailer that offers computer upgrade services.
Connect your second monitor using VGA cable. Restart your computer to detect the new monitor.
Adjust your display settings. Right click on the desktop > select "Properties" >click on "Settings" tab >locate your second monitor on the drop down menu> select "Extend my Windows desktop onto this monitor" options> click "Apply" or "OK."
Drag the monitor icons to arrange them in the same way as the monitors on your desk. Click the "Identify" monitors button to verify which monitor is 1 and which monitor is 2.
Now you have a second monitor set up through the VGA output.
im assuming you can get a screen to check the video card
Click the Windows orb logo at the bottom of the desktop to show the start menu.
Click the "Control Panel" from the menu to open a window.
Type "troubleshooter" in the search box in the top-right corner of the window. Click the "Troubleshooting" link that appears in the center of the window in the search results.
Click "View All" in the left pane of the window.
Click "Display Quality," and Windows will begin checking the computers video card adapter. Monitor the screen, answer the questions and follow the instructions if a problem and solution are given by Windows.
hope this helps
Aug 31, 2012 | Toshiba Computers & Internet
I have attached my Pinnacle DVD Recorder to my VCR and my PC. When start capture I receive invalid input signal and to check cables. I have everything connected so don't know where the problem is. ...
Hello Pavia,
Insert the Dazzle DVD Recorder installation disc in your computer. Click your CD drive and double-click "Setup.exe" Install and follow the on-screen instructions. Enter your product key and click "Accept" for the license terms. Click the option for a full or repair install to overwrite the corrupt installation, troubleshooting and resolving your issue with the software.
Jul 03, 2011 | Pinnacle Dazzle DVD Recorder
Hello, i got a asus gt440 1gb gddr5 on my pc, but i have install all updates and continue tell me that i dont have installed and got a problem called "Windows has stopped this device because it has...
One of the drivers controlling the device notified the operating system that the device failed in some manner.
If you have already run the Troubleshooting Wizard, you might want to check the hardware documentation for more information about diagnosing the problem.
Jun 13, 2011 | ASUS GeForce GT440 1G PCIe
RX1550-TD256E
try on new drivers,or set up in bios..
Apr 05, 2010 | MSI RX1550-TD256E RADEON X1550, (256 MB)...
Geforce rivers
This might be caused by a common conflict between your 7600 series videocard and your computers chipset. Try disabling "write combining".
To do this, goto the display properties (on the Windows desktop right mouseclick and choose "properties"). Then choose the tab "Settings" and click the "Advanced" button. Now choose the tab "Troubleshooting" and uncheck the checkbox "Enable writecombining" and click the "OK" button afterwards.
You might need to restart the computer afterwards before testing wether that solves your problem or not.
If that doesn't fix it, try other/newer drivers. And when that doesn't help things, you might have overheated the card (and damaged the RAM chips on it). You might want to clean any dust from the card anyways.
When the problem still occurs, please let us know, so we can continue troubleshooting ...
Aug 14, 2009 | XFX GeForce 6200 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
Cheers
May 09, 2009 | ATI RADEON X1650 Graphic Card
Troubleshooting
Here is a link to ATI's support site. Floow the links to download the latest drivers for your operating system. On this site also is a link for troubleshooting and setup options. I hope this helps you out. http://www.amd.com/us-en/SupportDrivers/ProcessorSupport/0,,15218_15219,00.html
Nov 27, 2008 | ASUS A9200 SE/TD RADEON 9200SE, (128 MB)...
Chaintech GSA73GT NVIDIA GeForce 7300GT 256MB (256 MB) AGP Graphic Card Logo
78 people viewed this question
Top Chaintech Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Ed Mac
Mark Taylor
Mark Taylor
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
