HP Compaq Evo n620c Notebook Logo
Posted on Feb 21, 2009
Sir i have hp520 note book. screen display not work if i connect moniter then display ok . can you help me?
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
I have trouble of my desplay, power work ok but can not display any thing
hey. there is a inverter in LCD that makes view brightly shinely so you can see everything on LCD. anyway. if the inverter breaks down you get black screen. even inverter is working you get blanc screen you need to check LCD DATA CABLE that it not possible to reach it for you. i advise you to get the Service if you have warranty
have a good day.
pls rate this.
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
2helpful
2answers
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Moniter problem
monitor is making sound when on
9helpful
4answers
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Hp notebook t2050 display problem in battary use.
you need to change the setting in your power manager, as your laptop is trying to conserve power, you can change the settings, however you may affect your battery life.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
