-the light inside stays lit, when you flip the signal lever up the clicking is faster than normal and the light sort of blinks, more like pulses quickly. The signal outside does not work at all. If the lights are off, then the signal light on the side of the car works but blinks fast while the one in the grill does not light up at all.
SOURCE: Jeep Liberty Left Rear Turn Signal Not Working
sounds like the bulb you have is the wrong resistance the new noen bulbs will do this
SOURCE: Saturn 2002 VUE Turn Signal not working properly.
You need to check your left side turn/park lamp bulbs for correct part # & installation.If that checks out you deffinetely have a ground problem.When you have other lights blinking with you turn signals you have either a bulb incorrect or a bad/poor ground.If bulbs check out check your forward lamp harness ground.Hope this helps
SOURCE: 2002 Hyundai elantra driver side turn signal not working outside
This simply means that the front driver side turn signal bulb has failed. Replace it.
Testimonial: "Thank you I will try that"
SOURCE: A problem with the indicator light. When I turn on
Check your bulbs first. Make sure they all work. If the bulbs are all good replace the turn signal flasher and your problem is fixed.
