Question about Sewing Machines
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Posted on Apr 12, 2011
    Problem Solver:
  • 6 Answers
Top tension is wrong.Make sure the thread is seated properly between the discs,and if that is OK,tighten the top tension very gently and do a few sample stitches.Repeat as necessary
Posted on Feb 21, 2009
When im threading my machine and start sewing all the thread starts gathering up arond the bobbin ; any surgestions plz steve ov sunderland
Posted on Oct 06, 2011
My stiches are uniform but about every 12 stiches there is a long stich , can you tell me what is causing it?
try to decrease top thread tension a 1/4 notch
check with new needle (may be bent and hook is missing the thread loop)
Nov 10, 2015 | Sewing Machines
When I sew, the stitching is loose with large loops on the underside of the fabric making the bobbin thread slide out easily. How do I fix that?
Lift the pressue foot off the fabric. Hold the thread spool with one hand and lightly pull the thread hanging out the back of the needle. This should seat the tread into your top tension discs properly. Now try sewing again. If it still throws loops, you either do not have your machine threaded correctly or your tension on top is set to zero.
Sep 01, 2014 | Bernina Sewing Machines
Singer 27
What kind of thread are you using. The most often problem today is that the thread is too thick for the size of needle. Try using a Metallica size 90 or a top stitching needle size 90
if the thread is a cotton type or a quilting thread it is often to thick to travel easily through the eye of a needle quickly to form a good stitch.
Aug 03, 2014 | Singer Sewing Machines
Tension problems
Yes the covers come off all machines. That does not mean it is easy to do. Since the problem is not on every stitch I would check the tension by installing a size 80 needle put the presser foot down and pull on the thread towards the back at a 45 degree angle to the direction of sewing. The needle should bend about a 1/8 to 1.4 inch at normal tension. If the tension is steady it could possibly be other reasons that the loops are forming under the fabric. Such as a burr on the hook, or bobbin case, lint, or clearance between the positioning devices for the bobbin case. I made a video about tension problems that are not actually caused by tension.
I also did one on common repairs for a top load bobbin sewing machine.
Nov 17, 2013 | Singer One Plus Computerized Sewing...
My singer sewing machine model # 774 will not produce a lower stich that is not all jumbled on the underside of the fabric. The upper stich is fine, it's the bobbin stich that comes out all jumbled. ...
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 08, 2011 | Sewing Machines
I have a Simplicity Fashion Pro SW2145. My bottom stiches are loose loops and it becomes a mess when I try to sew. I have changed needles, rethreaded, cleaned all lint, oiled, and it has not fixed the...
Most likely caused by issues with your top tension if it is showing on the underside of the fabric, top thread is not being tensioned fully or at all. Check the tension dial is set to five and that the top thread is between the tension discs and under tension.
Best way is to lower the pressure foot as this engages the top tension. Then pull the thread from below the tension device, down near the needle bar, it should feel firm to you.
If not, then check top threading again, rethread and pull thread into the tension device, and test again. If there is some tension there, then you could try turning the top tension dial up to a higher number a little to see if this helps with the stitching.
Failing that, take it for a service, tension device is probably faulty.
May 24, 2011 | Simplicity Fashion Pro SW2145 Mechanical...
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Jan 27, 2010 | Singer Sewing Machines
Singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
Sep 21, 2009 | Singer 57817 Computerized Sewing Machine
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
1,075 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
