Question about Buffalo Technology WCA-T 802.11b Wireless Access Point
WEP key problems
PRIMARY DNS CONNECTION PROBLEM AND SECONDARY DNS PROBLEMS
  • pontelemon
    pontelemon May 11, 2010
    What's the default ip ?
    What's up with WEP key?
  • Pat Batta
    Pat Batta May 11, 2010
    what kind of problem?
    it's not clear: wep key or dns config in your network?
  • 611 Answers
Primary check from the isp provider and second same check with isp provider. before just check it this go to start--->run---->type there ping 4.2.2.2 then enter it its replying then is working fine other wise contact the isp people
Posted on Mar 03, 2009
  • kalpesh jain
    kalpesh jain Mar 03, 2009
    primary check from the isp provider and second same check with isp provider. before just check it this go to start--->run---->type there ping 4.2.2.2 then enter it its replying then is working fine other wise contact the isp people
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
I need to find my dns and secondary dns for a dynex wireless g router
Try typing your IP address into your browser (Internet Explorer)
Hope this helps!
Feb 06, 2010 | Dynex Enhanced-G Wireless Broadband Router
Netgear wireless n modem router type DGNB2100-100UKS problem dropping out on games when playing on xbox live
You can consider following steps to for the x-box live with netgear dgnb2100:-
a)Get any computer which has the internet access to it , Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go.
b)Enter the username and password for the router (Default username is admin and password is password).
c)You will be navigated to router administrator page , you will have a blue/purple column on the left hand side which has the different setting options in there.
c)From the browser Main Menu select Advanced and then the sub-title WAN Setup.
d)Under WAN set up,check the box for Default DMZ Server enter the server's IP address[192.168.0.20] the corresponding box for the IP Address.
e)Click Apply.
ON X-box live:-
a)Open the main menu and under setting's select wireless set up and then select manual setting's , it will ask to enter the following information:-
ssid(broadcast name)
security type(wep/wpa-psk) and password to it
ip address:-192.168.0.20
subnet mask:-255.255.255.0
default gateway:-192.168.0.1
Primary DNS:-192.168.0.1
Secondary DNS:-leave that blank and apply the setting's
b)Go for the connection test and it will have the successful connection.
This Link will be of great help:-
http://kb.netgear.com/app/answers/detail/a_id/1118
Nov 28, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Wireless connection picks up all connections even though i have a WEP password.
this is simple.....
Try to create a name for your wireless network.. and try the WPA encryption and not WEP which is not secure....
was i helpful enough?
I had the same problem, now i have none...............
how?
login to....
http://primustel.blogspot.com
and find out how............ Check out the ONSPEED banner
and also run a PING TEST. Good Luck
Jun 17, 2008 | NetGear RangeMax Dual-Band Wireless-N...
Secure wireless connection with WEP but still picks up all wireless connections
If the unit has WAP as an option, use that instead of WEP. If enabling this still does not prompt you for a key, or you don't have this option, check here to make sure you have configured it properly... http://kbserver.netgear.com/kb_web_files/n101675.asp
If that doesn't help, check this firmware page and upgrade... http://kbserver.netgear.com/release_notes/d103242.asp
Hope this helps! : )
I can't use internet
Assuming that I am understanding your problem correctly, you can connect via your wireless access point, but Internet Explorer isn't working on your computer? Does the problem exist on the other computers as well? It would appear that you have a connection, just no browser. If the problem is simply the browser not working on one computer (your laptop I presume), then download another copy of the browser on a different computer, save to a flash drive and reinstall it on the problem system. The browsers can cache web pages temporaily and stores the URL's to recently visited web pages in the history folder. I also would suggest having more than one browser on every computer because of problems like this. The most popular and sometimes the primary browser used is Mozilla Firefox from www.mozilla.com. Browsers do not resolve the web domain name (URL) This name resolution is performed by a Domain Name Service Server (DNS). Your ISP most likely also has a DNS server and provides the address resolution for your queries on the internet. Hope this helps.
Dec 06, 2006 | D-Link DWL-G700AP 802.11g/b Wireless...
Buffalo Technology WCA-T  802.11b Wireless Access Point Logo
79 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
