Question about Photography
I need to replace the platform locking lever on Velbon PH 157Q
I dropped tripod and the platfrom locking lever smashed and is unrepairable, it looks like I could uncrew it and replace it but cannot find anyone who supplies parts - any ideas?
5 Suggested Answers
SOURCE: Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Posted on Apr 16, 2008
Midwest-tech
  • 243 Answers
SOURCE: Velbon VGB-3C
i have had this happen before many times. You can just pick up another bolt and fastener from your local hardware store that will fit in place of the original. It takes a little bit to find the right ones but they had the right ones.
hope this helps.
thanks,
Nate
Posted on Aug 22, 2008
SOURCE: parts for a velbon tripod
hi there, i think you can obtain the parts directly from Hakuba USA. www.hakubausa.com they're the USA distributers for Velbon and will actually repair it... if you can't by simply replacing a part. also a phone # 1-800-423-1623 and a seperate # 800-886-2236 to order quick release plates.
Posted on Jan 05, 2009
  • 24 Answers
SOURCE: Quick Release Platform for Velbon Stratos 460Q Video.
Try http://www.tripodquickrelease.com/Velbon_Quick_Releases.htm They have all kinds of tripods listed by head and tripod model number. You should be able to get it there.
Posted on Feb 10, 2009
  • 5 Answers
SOURCE: Where can I find a Velbon Ph-268 tripod platform
ebay
Posted on Jul 18, 2010
Does the Velbon cx-300 fit most camera's
If your camera has a 1/4" thread socket on the baseplate, it can be fitted to the pan and tilt head in the illustration of this tripod provided by a Google search. The manual should give you definitive information if you are still not sure.
Jan 09, 2017 | Velbon Photography
Photography Logo
833 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
