Question about Canon NP 6050 Copier
False jamming at duplex unit
There is jamming at duplexing unit message appers on screen ..but actually there is no paper jammed in duplex..so we can not do the double sided copy ..
please help
IT THE BIPASS ROLER THAT IS NOT PICKING THE PAPER
Posted on Jan 10, 2011
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Posted on Feb 23, 2009
How can i fix my kyocera fs2100dn printer there is no paper but it says paper jam in the duplex unit
Hie firstly i would advise you to check where you had that paper jam if the sensor is in place because that will give you false paper jam
Feb 24, 2017 | Kyocera Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Apr 01, 2010 | Minolta DiALTA Di183 Copier
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
Ricoh 1045 false jam
"Z" is the duplexer as I'm sure you are aware. Have you swung it away from the machine and ALSO lifted up the black guide (with blue handle) to check behind it?
Have you also, just opened the upper cover of the duplex unit on the right side of the machine (without swinging the entire unit away from the machine)? If there is actually no paper stuck in it then there may well be a switch that has become dislodged, and you'll need to call somebody...OR, you could disconnect the duplexer:
Turn off main power (red button), and remove the connector cover for the duplexer (towards back of machine at bottom of duplexer), by removing 1 x phillips screw. Unplug connectors, and turn machine back on. You won't be able to duplex but the machine should work.
Good luck, and please rate my solution
Apr 06, 2009 | Office Equipment & Supplies
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Canon NP 6050 Copier Logo
322 people viewed this question
old marine
old marine
