Question about 3Com OfficeConnect Wireless Router
3com router encryption
Hi, thanks for your previous help(very good), I have a 3com 3CRWDR100A-72 router that I have connected to a bt router, I am using the 3com router as an access point but I am a bit stuck on how to get the encryption code from the bt router onto the 3com router. I plan to add more access points and was hoping I would not have to manually change all of them as the encryption code on the bt router gets changed every day.
  • 72 Answers
Go to option menu-click the security option
Se the password under the any one of the security parameter
save the configuration
Posted on Jan 04, 2010
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
Dec 14, 2009 | 3Com Wireless LAN Access Point 7250...
Trying to connect to wireless network. No options for WPA encryption code on my 3com assistant.
When connecting to locked wireless network, u need to insert the correct password/key in order to access.
Jul 19, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Router works on and off.
turn off dhcp on one of them.
May 04, 2017 | 3Com (3CRWE51196) Router
Trying to configue a 3com router as an access point
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
Feb 20, 2009 | 3Com OfficeConnect Wireless Router
3Com 7760 (3CRWE776075US) 802.11a/b/g...
Hi there
I think up to now you've been using someone else's Internet service, by picking up the signal wirelessly. You need your own Internet Service. You now connect your access point in the way the Internet Service Provider guide you. It is a different set up with cable (they provide a modem) or with BT (connection through your phone line).
Dec 31, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
3com Router and Panasonic BLC30 wireless camera
The solution I used was. I had a second router/ap that was wireless.
I then associated the #2 router/ap to the WPA main router,
And ran the Camera on wired mode thru the 2nd Router.
When you use an ext renal wireless AP that camera.
You get much better range. I had a che-po router.
And the range was 3x what it was using the cameras antenna.
Also Here's a back door to Panasonic FTP with all the camera related software they put out,
ftp://ftp.panasonic.com/pub/Panasonic/cctv/downloads/
Sketchlab.com
Dec 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Cannot sync with my 7Mb adsl
quite often, if the router works in other houses, contact the telephone LINE company to see if there is a problem there. Alhough tiscali aren't always very helpful, ask them to do a line test and see if there is a problem with the signal to noise ratio on the line
Aug 28, 2008 | 3Com OfficeConnect Wireless Router
3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Mar 20, 2008 | 3Com OfficeConnect Router
3COM Office Connect 3CRUSB10075
are you using windows xp? vista? 98?
I'll guess at xp.(and that you're using the windows software to connect)
Double click the wireless connection icon in the bottom right (the one that flickered when you're online.
Click 'view wireless connections'
click 'change the order of preferred networks'
Now select everything on the list and delete it apart from your own.
Now click 'advanced'
make sure 'automatically connect to non-prefurred networks' is NOT ticked.
Click close, then ok.
You should be ok now.
Regards
Tony
Feb 28, 2008 | 3Com (3CRUSB10075) 802.11g/b Wireless...
3Com OfficeConnect Wireless Router Logo
279 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
