Question about Mitsubishi CS-27205 TV
Our Mitsubishi TV is flashing a blue screen every 10-15 seconds?
The sound is fine on the TV, but it won't keep from flashing this blue screen. It started a few months ago, and would eventually go away after an hour or so, but now it's constant.
Any advise is great! Thank you.
    Problem Solver:
  • 9 Answers
Two questions for you.
1. What is the model of the set?
2. What sources are you trying to watch? Are you on cable, satelite, dvd player, vcr,
which of these are you watching and does the problem occur on all sources or just
certain ones?
Not having the above information, I will give you some information. Blue screen comes up
on these sets because of a loss of video signal. First thing you should do is to check your
cables between your sources to see if a wire has pulled partway or now completely out
say between satelite receiver and set. You might replace the cables in case you have
a broken wire inside the cable.
Some sets have the ability to go into the menu and shut off blue screen so you can
then see what the video looks like even if it is low level. From there you can do some
diagnostics by wiggling or connecting/ disconnecting the cables.
Beyond this there could be a loose connection internal to the set or a part failing, but
be sure to check for those cable connections first as that is the most likely cause. Also
it is good to try it with another video source or test the source on another set to be sure
that the video source hasn't developed a malfunction.
Posted on Feb 21, 2009
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
My Mitsubishi TV is flashing a green light and gos to the blue welcome screen,does anyone kno what wrong with my tv?????????
I have an old Mitsubishi Tv , your instruction manual is good and thorough and if you don't find it there check online with use the support section there.
Jul 14, 2012 | Mitsubishi WD-73C9 73" DLP TV
My Mitsubishi wd-65731 only displays a blue screen. It has been working fine for 5 years now.
Check video source first. Check other inputs. . Then hold down first and 3rd button from the right on tv for 5 seconds until green led flashes. count the flashes. It will flash several times pause then flash several more times. This is a code 2 digits. Let me know what code is.
Aug 30, 2011 | Mitsubishi WD-65731 65" HDTV
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Help with my big screen mitsubishi ws65869 tv
my screen is a right blue with no picture although I have sound it reads "tuner out"
Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
