Question about Gigabyte GA-8I845GVM-RZ Motherboard
System not rebooting after BIOS update
After updating the BIOS using @BIOS and choosing option Update Online, it asked for restart and after restarting no display is there, only my CPU fan is rotating and power LED is on. Please help me in solving this problem. My motherboard is Gigabyte 81845GVM-RZ
    President:
  • 1,223 Answers
May be u have flasshed a wrong bios to ur mother board u have to take it to service centre it basically bios dead can be repaired at cost , try removing RAM and then re install them see if it works
Posted on Feb 21, 2009
Can you boot from usb on a sony vaio pcg-9s1l
You may need to "Flash" (Update) the Bios. To do this, go online and download the latest Bios update for your machine.
Unzip the downloaded file and place it on an empty Memory stick.
Insert the memory stick and restart your machine. The Bios update should install.
Wait for the process to finish and then see if you now have the option in Bios>Boot Options to Boot from USB.
May 14, 2014 | Sony VAIO Notebook
When i put my loptap elietbook 2530p on slleep mode after that not give disply and not stand up please hep me bro
1. Make sure your windows is up to date with windows update
( thats if you have windows, you didnt say if you did or not, when asking for help give as much info as you can)
2. Go here Make sure this is your right laptop, if so update your drivers with the ones on there make sure you have the right ones if you dont it wont let you install them, update your bios last and after you update your bios it should be fixed.
3. Do not turn off the laptop or unplug the laptop when updating bios, if you do your laptop WILL NOT WORK AFTER. so remember do not turn off PC or unplug.
4. it will restart on its own usally, sometimes it will ask you to reboot. reboot is a must,
Dec 03, 2013 | Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
My computer screen went completely white. I have a Dell flatscreen monitor
This issue occurs due to various reasons. However, in this case it might be due to corrupt BIOS settings. To resolve this issue I recommend you to visit the following website to download and install the BIOS Update:
===Installation Instructions ===
1. Download the BIOS update. (from Dell website)
2. Double-click the BIOS update icon, and then click NEXT.
3. Accept the license terms, and then click NEXT.
4. If an Overwrite Protection message appears, click YES TO ALL.
5. Click OK at the Windows Based BIOS Update window.
6. Click YES at the next Windows Based BIOS Update window, and then wait for the update to complete.
7. At the Windows Based BIOS Update window, click YES to restart your PC.
8. If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
Default BIOS settings have been loaded due to BIOS update or checksum issue.
Press to enter Setup. Otherwise, allow the PC to continue.
9. Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Also use a sytem utility software RegInOut -- a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of
Internet Optimizer enhance users web browsing experience.
Dec 19, 2011 | Dell Computers & Internet
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
MY LAPTOP WENT OFF DURING UPDATES NOW IT WONT FINISH LOADING, it comes up update 3 of 3 then restarts and says same again keeps doing it not letting me in to lap top anymore seems stuck on updates
Hold F8 while booting to go into safe mode, or last known good configuration. Then, preform the update from there, and that should fix your problem.
Feb 28, 2011 | Acer Computers & Internet
Trouble Updating BIOS: Medion M3 Director 5100
plz check the fsb of ur new memory.plz conform it the memory is supporting ur motherboard.
Jan 15, 2009 | Medion M3 Director 5100 PC Desktop
Gigabyte Socket A GA-7VA Bios update failure
You can try to save the motherboard w/ a floppy, and if that doesn't work, go to gigabyte's website and request for an RMA. I made the same mistake in trying to update the BIOS through @BIOS after it updated, it assked for me to restart the pc, and when i did, the was nothing. All i heard were the fans. Nothing on the screen, and it obviously wasn't posting. So go to Gigabyte so you can get another one, and tell them there's a flaw w/ the application @BIOS. If by any chance you update the BIOS, try it w/ a flash drive under DOS. Good luck.
Nov 09, 2008 | Intel Motherboard
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Gigabyte GA-8I845GVM-RZ Motherboard Logo
293 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
