Question about Intel PIII 600MHZ/ 512KB/100MHZ SECC2 p/n BX80525U600512E (BX80525U600512EB)
What is the difference in CAT 5 and CAT 6 cable
Networking
  • 837 Answers
CAT-5 is rated to 100M with 24 gauge wire
CAT-6 and CAT6e is rated to 550M with 23 gauge wire
But as a note .. Cat 6 really has not been been approved and has no definitive specs yet .. Use Cat5e
Posted on Feb 21, 2009
Color code for wiring plugin
I'd like to help you. Can you clarify? What 'wiring plugin' are we talking about? Presumably, you're trying to plug a wire of some kind into something. There are different color codes for almost every different kind of cable; without knowing which one you are asking about, your question is impossible to answer.
What wire are we talking about? What is this wire meant to connect to (on BOTH ends)?
This is just a guess, but since this is in the 'router' section, you may be asking about network cables. I've attached an image showing the wiring diagram for both normal and crossover cables:
Additional information and network-cable wiring pinouts can be found here:
How to Make Category 5 Cat 5E Patch Cable
Best of Luck!
May 31, 2015 | Computers & Internet
No. i am looking for D-link network cables,cat 6 and cat 5.
If you are looking for network cables (cat 5e and cat 6) you can try this site:
http://www.monoprice.com/products/department.asp?c_id=105
Amazon.com also has good network cables for low cost.
I hope this helps
Mar 24, 2011 | D-Link Computers & Internet
How to connect RJ45 cat5 cable in wallmount I/O box
how i can punch cat 5 cable in cat 5 io box
Mar 01, 2011 | Leviton (102-5G108-RW5)
When I plug a cable into port 8 it will shutdown the switch
Your router supports a total of 8 connections. However, on the back there are 9 physical ports. Port 8 has two physical connectors where one (we will call it port 8a) is used to connect to a PC and the other (we will call that port 8b) is used as an uplink port. The uplink port (8b) cannot be used if something is pluged into 8a. If you are trying to use all 9 physical ports that is likely ther problem. If you need more than 8 devices connected to your switch get another 8 port switch (any brand will do) and connect the two switches via the UPLINK port with a 7 foot CAT-5 cable. Do not use a CAT-5 patch cable less then 7 feet long to connect two network devices together such as computer to switch or switch to switch as that will probably cause another problem with timing.
Another possibility is that the device at the end of port 8 has a malfunctioning network adapter. Try connecting a laptop to port 8a using a 7' CAT-5 cable. You may also want to try pluging the problem cable into another port as a way to test if the problem is somewhere along the cable run.
Oct 29, 2009 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Where is the cap 5 cable located?
The Question is not clear. Pls be more specific
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Hookup westell modem to belkin wireless router how to
Telephone cable from wall to modem..Cat 5 cable from modem to Router...You will have to also get another Cat 5 cable for initial set up an hook it from the router to your PC..That is so you can get into the Router software and set your settings, such as network name and encryption. Once the settings are completed then you will have Phone cable wall to modem, Cat 5 from modem to Router.You can unhook the cable you initially had from the router and your PC...if you have any questions just let me know..
Pls rate this solution.
Apr 29, 2009 | Belkin (F5D7231-4) Wireless Router
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
200 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
