Question about Kitchen Ranges
My Westinghouse Avondale 529 hotplates go red hot when on medium heat setting, sometimes even unable to turn off. This has happened to both front hotplates but doesn't happen every time.
  • 311 Answers
SOURCE: I have an electric range
You need to replace the burner switches. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
  • 86 Answers
SOURCE: Whirlpool Electric Range coil element gets red hot at low setting
Hi, Your problem is with the regulator switch! This is just a simple replacement of the switch unit. The tricky part is getting it to pieces to install the new one. If you can send me the model i might be able to assist you with taking it apart....
Get back to me if you need any further help......
Posted on Jan 02, 2009
  • 219 Answers
SOURCE: coil heats to glowing red
the infinite switch for that eye
Posted on Mar 24, 2009
SOURCE: The burners either don't come on or they have to
Let me get this straight. You want me to pay you to fix this problem.
But, if I already found a solution you want me to tell you what solved it !
You must have a really over sized uterus !!!!!!!!!!!!!!!!!!!!!
Posted on Oct 19, 2009
  • 447 Answers
SOURCE: hot plates go red hot even on low setting on my
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
Posted on May 16, 2010
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
The left front burner will turn on for a few seconds then turn off then back on and off. It would not heat the pan on it. This is a glass top range. Are there any tests that I can do to find the problem?...
If the rest of the hotplate elements are working correctly and you are performing the same tests with all of them then you have a problem. We know that the hotplate works. When hotplates are faulty they don't turn on and off, they just don't work. This would generally be a hotplate controller problem. It sounds as if the controller is faulty and requires replacing. If you are handy you can switch the suspect hotplate controller with a good one and see what happens. This will confirm our suspicions.
Mar 04, 2011 | Kenmore 96412 / 96414 / 96419 Electric...
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
May 16, 2010 | Ovens
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Dec 15, 2008 | Ovens
Steamer will not work
Make sure your milk frother is not blocked.
Aug 14, 2008 | Gaggia Titanium Espresso Machine
Kitchen Ranges Logo
353 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
