Question about HP Compaq Presario v3000z Notebook
Compaq presario v3000 prob sata enable mode do not work why ? bios F 26 phoenix
  • 413 Answers
It works with raid controller or with vista ultimate
Posted on May 07, 2009
Compaq presario v3000 sata will not detect or format for operating system
Hard drives can go out in any model. If you have created a restore set, you can replace the hard drive with the same size or larger.
Hope this helps
Mar 26, 2012 | HP 417065-001 - HP Compaq Presario V3000...
I have not continuing windows xp. if i start xp installation then the blue screen appears. i want to know to change bios setup on sata mode
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 27, 2011 | Compaq Presario Notebook
Unable to boot compaq presario v3000
First when you power up press F2 or "del" key to enter in bios then load optimal defaults.
Then go to advanced and set "SATA disabled"
then save all settings then check .
Also check your harddisk is detected or not.
Let me know sir.
Jul 16, 2009 | HP Compaq Presario v3000z Notebook
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
SATA driver for compaq presario v3000
Hi there.
What you need is Intel matrix storage manger for sata drives, go here read the info and download the drivers you need:
http://www.intel.com/support/chipsets/imsm/
Good luck and thanks for using Fixya!!
Feb 24, 2009 | Computers & Internet
Dear Sir I'm unable to install the Windows Xp in my new laptop i think this problem is with sata HDD so can i download the drivers and install in my laptop
check in bios settings the sata hard disk detect or not.if not detect then u cant install. Reset your bios settings to defaults settings then save and exit.
also check your sata option in bios is enable.try in both situation sata enable and then try sata disable.
Dec 27, 2008 | Compaq Presario Notebook
About compaq presario v3000
use windows xp operating system with service pack 3. or use vista operating.
Dec 06, 2008 | Compaq Presario Notebook
Driver probs
Here's a link where you can download the drivers for your presario v3000 laptop.
Compaq Presario V3000 CTO
Nov 06, 2008 | Compaq Presario Notebook
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
HP Compaq Presario v3000z Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
