I have tried the solution of disabling monitoring for messenger but my system would not let me save the cahnges to the saset.ini file.
0x8ac70013 msn video call are not working
Solution A: If you using McAfee Antivirus, the following steps will configure SiteAdvisor to stop monitoring windows live messenger. Go try solution B if you are NOT using McAfee Antivirus.
1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Solution B: I am using XP with NOD32, using the latest version 2009 (Build 14.0.8117.416) and here is the solution that works for me,
1. Sign off and Exit messenger
2. Go to C:\Program Files\Windows Live\Messenger
3. Right click on file "msnmsgr.exe", select "Properties", a new window of msnmsgr.exe Properties will pop up.
4. Under "Compatibility" tab, look for "Compatibility mode", if the box "Run this program in compatibility mode for" is checked and show window 2000. Go ahead un-check it.
5. Open messenger again and try to test the video call.
Mar 18, 2011 | Home
I was using Yahoo Messenger 9 then updated to 10. Once I updated the Yahoo Messenger User Id become disabled. I uninstalled the Yahoo Messenger then installed Yahoo Messenger 10 again, still got the same...
It seems that you tried to save your ID with Password to automatically login option, and by chance the id was empty, and it is mixed in Registry of your windows,
Step 1: Uninistall the yahoo messenger from your computer from control panel also remove yahoo browser services or toolbars installed
Step 2: Go to program files folder and delete yahoo messenger folder C:\program files\yahoo
Step 3: What you can do is to clear the registry entries of Yahoo messenger, Download C cleaner from the link below
Download Ccleaner
When download finishes, Install the ccleaner in you system, just run the setup file and follow on-screen instructions, to install, This program is basically for cleaning system temporary files and also has the addon to fix registry errors,
Installation Process:
2: Select I agree
3: Choose the options you required for your software
4: After the software installation is finished select to run the ccleaner bilalseham_10.jpg
5: Select Yes for cookie scan bilalseham_11.jpg
6: On main interface you will see Registry button in ccleaner software. Click on Registry
7: CLick on Analyze and it will scan all the registry for errors
8: It will now show you registry error files, Click on fix selected issues
9: now it will prompt you to backup registry, its a good thing to backup your registry incase if it gives you any error you can restore the registry later on
10: Save to the local drive or external media
11: After saving registry backup you will now see the screen to fix errors, (Error count will depend upon the softwares installed on your system. Select fix all selected issues
Restart your computer and install yahoo messenger again from the web, I hope it will not give you error any more,
If you require more assistance feel free to reply to this post!
thanks for contacting Fixya!
Regards, BA
Feb 05, 2011 | Yahoo Messenger
MSN Camera Problems
If you have both McAfee SiteAdvisor and Windows Live Messenger 2009 installed, please take the following actions until a patch is out from McAfee because there are some incompatibility problems.
The workaround is pretty simple. All you need to do is to disable McAfee SiteAdvisor from monitoring msnmgr.exe but there is no option to do that. You’ll have to manually go to C:\Program Files\McAfee\SiteAdvisor\ and look for the file sasets.ini. Open the sasets.ini with notepad or your favorite text editor, locate the section titled [msnmsgr.exe] and change the value to 0 (1 means enable and 0 means disable).
Save the file and close it. You can either restart your computer for changes to take effect OR simply terminate and reopen Windows Live Messenger 2009. Yeah it’s frustrating that Windows Live Messenger 2009 has so many bugs and incompatibilities but no worries, I’ll slowly help you all to look for solutions and workarounds to make it work rather than downgrading back to MSN 8.5. According to Wikipedia, Windows Live Messenger is no longer beta and the latest version is Build 14.0.8064.206 released on 12 February 2009. You can head on to Live Messenger to download the latest Live installer (wlsetup-custom.exe) which can automatically update your Messenger if it detected there’s an update.
Jul 12, 2009 | Computers & Internet
My webcam won't work on msn
download the new windows mesenger here http://messenger.live.com/ this would be easyist to fix the problem. or 1. Navigate to the following folder:
Jun 11, 2009 | Sony Computers & Internet
What is *.ini files ? how can i create it ? what is the use of it ?
.INI files are plain-text files that contain configuration information. These files are used by Windows and Windows-based applications to save information about your preferences and operating environment. "INI" stands for initialization.
Format of .INI Files.INI files contain one or more sections. Each section begins with a section name, which is followed by zero or more entries. An entry associates a keyname with a value. The general format is:
[section]
keyname=value
Comments can also be included in the file by prefacing the comment with a semicolon (;).
Windows and Windows for Workgroups use several standard .INI files for storing configuration information. These files are WIN.INI, SYSTEM.INI, PROTOCOL.INI, PROGMAN.INI, CONTROL.INI, WINFILE.INI, MSMAIL.INI, SHARED.INI, and SCHDPLUS.INI. Windows-based programs may also add sections and entries to WIN.INI, and they may add .INI files in the Windows directory.
Editing .INI FilesBecause .INI files use only plain text, they can be edited using any text editor or word processor. .INI Master also has a built-in text editor for making corrections in the .INI files you are diagnosing.
To create a custom Setup.ini file:
  1. Start the Setup INI Customization Wizard.
  2. Type the path to your Office XP administrative installation point, and then click Next. The wizard searches the specified network share for a Setup.ini file.
  3. From the administrative installation point, select an INI file on which to base your custom INI file. Or, click Browse to go to a different location and select a file. Click Next.
  4. Under Logging, select a logging mode, and then type a name for the log file or template. Click Default to use the logging mode that is specified in the INI file. Click Verbose to use all logging options. Note that verbose logging creates very large log files.
  5. Under Display, select a default display setting, and then click Next. The wizard searches the administrative installation point for additional packages (MSI files) that you can chain to the Office installation.
  6. Select the check boxes next to the packages that you want to include in your custom INI file, add packages or programs (EXE files) that are stored in another location, and then click Next.
  7. Use the arrow keys to determine the order in which you want Setup.exe to install the chained packages. The System Files Update package is always installed first (if required), followed by the Office XP package. You can change the order in which subsequent chained packages are installed.
  8. Select each package, specify the options that you want for that package, and then click Next. For each package, you can specify an MST file and a unique display setting, as well as additional property values.
  9. To add additional property-value pairs to your custom INI file, select a package, click Advanced Properties, type the properties and values that you want, and then click Next. The wizard displays a summary of the changes to save in the custom INI file.
  10. Click Save As, and then type a name and path for your INI file. The wizard supplies a sample Setup command line that specifies your custom INI file with the /settings option.
  11. Click Finish to quit the wizard.
May 12, 2009 | Microsoft Windows XP Professional
I have the same problem with dual boot Windows 7 and XP Pro
To find the actual boot.ini file you will have to make hidden operating system files visible. To do this, open a folder such as My Computer then go to Tools>Folder Options. Within the new window that appears, select, "View" at the top. Now scroll down just a little ways and un-check, "Hide protected operating system files (Recommended)." Now press OK.
Afterward open up My Computer (if it isn't already open) and double-click on your C:\ drive to look at its files. Within this region you should find the file named, "boot.ini."
NOTE: I do not recommend editing this file, as one mistake could corrupt your installation of Windows preventing you from starting Windows successfully. If you do edit the file, you do so at your own discretion and I in no way am responsible for any damages you cause through editing the boot.ini file.
Hopefully that's the information you were after. If not, let me know and I'll see if I can assist you further.
Mar 23, 2009 | Computers & Internet
Acer Aspire 5535 Webcam wont work on windows live messenger
I had the same issue when i installed new Messanger 2009. I found another thread that states that it is Macfee site advisore is the problem go toprogramm files / macfee / site advisor. in that folder look for the file sasets.ini....
right click on the file and open with notepad scroll down to see the following and change the (1) to 0
[msnmsgr.exe]
Enabled=0 ........... change the 1 in this line to a 0
Type1=0
Type2=0
NotifyChange1=0
NotifyChange2=275
EnumID=7
then save restart it shoild work
Jan 19, 2009 | Microsoft Windows XP Professional With...
Acer 5535 laptop crystal eye webcam problem
you have to set cam up with the program
After you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
if you still have a problem please let me know and don't forget to rate
Jan 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Crystal Eye Webcam and MSN Messenger
Straight from MSN helpdesk:
1. Click Start, click Run, copy and paste the following text: %SystemDrive%\Program Files\McAfee\SiteAdvisor in the Run box and click OK.
2. Right-click the file sasets.ini or sasets.dll and select Open With, then select Notepad.
6. Close sasets.ini or sasets.dll and restart your computer
Kathie x
Jan 09, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
