Question about RIM BlackBerry 7290
Error 365 showing blackberry 7290
I wan to format 7290 ???? can u hwlp me
    Genius:
  • 1,234 Answers
Hello Sir
To delete all the data, go into Options / Security Options / General Settings, clik the wheel and then click Wipe Handheld.
This will remove all of the DATA, and not any of the applications.
Posted on Aug 27, 2010
Hi mate i have blackberry 7290 its problem is whe i power onthe phone its giving following error "DEVICE ERROR:365 RESET" then i try to flash the phone but soft ware giving this message UNABLE TO...
Try uninstalling the Blackberry Software Suite and the Blackberry drivers from your computer from the device manager. Power off the Blackberry, then connect it to the USB cable to see if it begins to charge. Look for the device to show up on Windows. If it does not show up, try booting the Blackberry device back up. If you're still not seeing anything (and especially if the phone isn't even charging), it could possibly be a hardware issue.
Mar 18, 2011 | RIM BlackBerry 7290
Error 365
my blckberry show Enter ther blackberry to contiune??
Sep 24, 2010 | RIM BlackBerry 7290
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
7290 device error 365 help me
cause The BlackBerry device is unable to complete the initialization process. Resolution Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
Oct 31, 2009 | RIM BlackBerry 7290
Devce eror 365 reset
In alot of cases Device Error 365 means the unit is dead.
365 is hardware error. Some cases it has been resolved with forced OS reload, but in many cases it's dead
Jul 09, 2009 | RIM BlackBerry 7290
Dvice error 365 reset
In alot of cases Device Error 365 means the unit is dead., it's not ever gonna work again.
May 31, 2009 | RIM BlackBerry 7290
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Mar 01, 2009 | RIM BlackBerry 7290
Dicice error 365
pls Send Solution
Sep 09, 2008 | RIM BlackBerry 7290
i am facing same issue error 365
Apr 09, 2008 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
74 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
