Question about Electrolux EW1200i Front Load Washer / Dryer
Error code e40 on electrolux ewf1087 - Electrolux EW1200i Front Load Washer / Dryer
  • Anonymous Apr 21, 2009
    I have the same problem, if I press the start button after the error appears the machine tries to start the cycle again, then there is a loud click click noise from the right hand side of the machine?
    Any ideas to try out there?
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Posted on May 10, 2009
e-Guru
  • 3917 Answers
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Posted on Aug 06, 2009
torres No9
  • 27 Answers
SOURCE: Hi, I have an Electrolux EWF1087 which is flashing
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Posted on Jun 25, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Hi I have an electrolux front
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
Error code E40 on a Electrolux Front Loader Washing Machine EWF80743. What does it mean and how can I fix it?
E40 relates to door lock faulty or not closing - you probably need a new door lock, but check the catch on the door hasn't snapped off first. You will also get E40 if you try to start the machine with the door open.
Dec 01, 2017 | Electrolux Washing Machines
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
Mar 23, 2016 | Electrolux Washing Machines
Electralux Surface Cooktop, with code---E----40
Hi Linda Wallman, thanks for your post!
I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 20, 2014 | Electrolux Cooktops
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
Error code e40 on my washing machine electrolux ewn 16781 w
Aug 06, 2009 | Electrolux Washing Machines
Electrolux ewf1074 error e40
Apr 09, 2009 | Electrolux Washing Machines
Electrolux EW1200i Front Load Washer / Dryer Logo
384 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
