Question about Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB Hard Drive
Toshiba 1TB External HDD having connectivity problems
Chaps,
If anyone can shed any light that would be awesome.
I have a 1TB Toshiba external HDD. When I connect this onto my laptop it is not recognised. It seems that the External HDD is working as the blue light is on. It does make that little noise initially when it is switch on however it does not appear anywhere to be connected onto the machine. I have checked in the Computer Management ->Storage->Disk Management section and it does not appear there either.
I have tried this drive on another laptop and desktop machine it doesn't seem to be recognised there either. I have checked the USB port of the machine, which seems to be working fine with my Tom Tom connected onto the machine. I have checked the USB cable for my External HDD with another external HDD that I have and it seems to be working fine.
I have rebooted the machine numerous times to no avail and I have also rebooted my External HDD a few times as well.
Can anyone shed any light on this problem?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
I have a Toshiba 1TB external HDD. Now it cannot be read by my computer. Regards
plug it on the back of the panel not on the front, or try to plug to other computer, if the problem still thesame then your external drive would be the problem.
Sep 01, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba 1tb external HDD that works fine on TV not on PC anymore
Try using it on another computer. If it doesn't work the drive may be bad.
Mar 14, 2010 | Western Digital My Book Essential Edition...
I have a Toshiba 1tb external hdd (px1396-3t01) and when i connect it to my laptop i see a blue flashing light..The disc is not recognised by the laptop! what can i do..???????
How old is your laptop? Are you running at least Windows XP Service Pack 3? If so, Right-click My Computer, then left-click Manage\Storage\Disc Management. Do you see your 1TB HDD listed? If so, is it described as Unallocated Space. If it says that it's Unallocated, then right-click in the black area and choose format, then follow the prompts from there. You should probably format it as NTFS. Be careful not to accidentally format a drive other than your 1TB HDD. If you don't see your drive listed in Disc Management then double check your connections. If all is connected well, then you should probably return it to wherever you bought it.
Nov 30, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
External HDD not working , but can here it running
Have you tried powering it up without connecting it to the computer?
It should at least power up and do something. After that try connecting it to your PC (with the disk powered up already).
You can further check this external drive troubleshooting article, which has some tips on trying to get external disks to work.
Jules
Apr 19, 2009 | Western Digital My Book World Edition 1TB...
Problem with WD EXT Network HDD (1TB)
Have you set up the drive as shared on your network?
Apr 15, 2009 | Western Digital My Book Essential 1TB...
My toshiba laptop is not giving the display at all?
Does the computer boot up?
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Computers & Internet Logo
469 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
