Question about LG LHT854 Theater System
Lg lht854. VSM mode problems
When pressing the vsm button the surround sound only goes through the vsm and bypass mode. i cant adjust the other surround sound parameters. really pisses me off
Connecting xbox 360 to LG LHT854 Theater System
you cant you have to use a fiber optic cable from your xbox to the lht854 then just hook the HD cable from the Xbox to the tv i have the same surround sound and had the same problem.
Dec 08, 2012 | LG LHT854 Theater System
LG LHT734
how old is this sety?
May 10, 2008 | LG LHT734 System
LG HT752TH Surround sound system rear x2 and centre speakers do not work even tho connected and tested correct.
They will work only if the source signal is itself 5.1. If it's stereo then you must convert it to 5.1 using the Virtual sound setting (press VSM to access it and select 5.1).
Sep 02, 2010 | LG LH-T754 Theater System
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
LG LHT854 Speaker issue
Have you tried the VSM (Virtual Sound Matrix) button on the remote? I think you will have to scroll through the various sound processors ie..stage...virtual matrix..etc...to find the one that will have all surround speakers working. Hope this helps
Nov 05, 2009 | LG LHT854 Theater System
Center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Jul 07, 2009 | LG LHT854 Theater System
I, have a LHT874 theater system no sound when watching tv
HI, check if you have to turn up the outputs on your tv or even switch them on,also make sure you are useing the audio outs and not an input then set your system to the same input the cables are pluged into and set sound to prologic 2.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | LG LHT854 Theater System
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
Sound with television
i have the same problem, has anyone found a solution?
Jul 31, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
LG LHT854 Theater System Logo
272 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
