we have a GE Profile, french doors, bottom freezer. Some time overnight the kitchen breaker flipped. Reset it this morning but fridge seems dead, no light, no temp gauge, no fan, nothing. I unplugged it for 30 minutes then plugged it into a different outlet, still dead. What should I check first?
Comments:
Feb 21, 2009
- Other appliances work properly when plugged in the same outlet
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
PSS26SGRE SS- Just replaced the water filter, it worked fine for 2 days. Now, no water at all....
(More)
PSS26SGRE SS- Just replaced the water filter, it worked fine for 2 days. Now, no water at all. Thanks.
ge refrigerator with smartwater plus, can not install the filter cartride because the holder is...
(More)
GE REFRIGERATOR WITH SMARTWATER PLUS, CAN NOT INSTALL THE FILTER CARTRIDE BECAUSE THE HOLDER IS DAMAGED.CHIPPED.
GE Profile refrigerator model no pds22mbraww. Some times when the door is opened the inside light...
(More)
GE Profile refrigerator model no pds22mbraww. Some times when the door is opened the inside light and gages will not turn on. If you hit the side, shake the refrigerator or trip the inside switch, lights and gages turn on (compressor also starts). Manually pushing the switch may or may not turn on the unit. If the door is open and I bang on the upper panel around the switch, lights come on and the unit starts cooling. The problem just started and happens every few days, not continously. I have cleaned the power connectors at the lower bottom of the unit, but this did not fix the problem.
