Question about Intel D102GGC2 Motherboard
My PC is working but corrupted NTDLR file, the time I was replacing it was going well to BIOS however, Keyboard started not be workig, when I put MEPIS LINUX, it show that Keyboard is working. Could you please help
  • 564 Answers
http://support.microsoft.com/kb/320397
Here is what you need. Just click the Link Above  . Please Rate My Response! Thanks!
Prem
Posted on Feb 21, 2009
Need to download dell sata drivers to install windows xp
Do you the install disc.put it your cdwriter.let windows start from it and loading files.choose then to repair the computer.if that do not work but it should.try CMD in safe mode.as Admistrator write. SFC /SCANNOW it will tell you if it is any corrupt files as you think good luck mike.
Apr 02, 2013 | Dell Dimension 3100 PC Desktop
Ntdlr error
This usually occurs if you have a memory stick in the computer, the computer will try to boot from this instead of booting windows. If there is no memory stick in the computer, your hard drive could possibly be corrupt.
Mar 28, 2011 | Microsoft Windows XP Professional for PC
Why i always encounter NTDLR is missing????
The NTDLR file is either missing or corrupted. This is a essential system file for Windows to operate. Please click on this link and follow my instructions to repair missing or corrupted system file/s :-
http://www.fixya.com/support/r4482455-repair_windows_xp
If this doesn't work you will need to reinstall Windows.
Aug 11, 2010 | Computers & Internet
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
Every time i turn the computer on it freezes at the logo e machines when it starts and i cant press nothing on the keyboard, it doesn't detect it and its not the keyboard i even used a six pin keyboard i...
You say that you pressed all the fx keys and delete key. Were you trying to get into the BIOS setup? If the keyboard is frozen no amopunt of key combinations will work. You might have to reset the BIOS to default settings. That means connecting a couple of pins together for a short time on the motherboard. You may need the manual if you don't already know what pins. Just make sure the power is completely of and the mains cord is pulled out.
It can vary the amount of time required to reset but if the corrupted BIOS was not caused by an overclocking it should be instant.
Once it is reset put the pins connector back the way it was. You may then want to go into BIOS setup, to set things up again to your preferences or needs. Again depending on your knowledge have the manual with you.
Nov 26, 2009 | E-Machines eMachines T3830 PC Desktop
Pc keeps rebooting, function keys don't work
Disconnect external peripherial.Drain flea power,connect know good keyboard,tried to boot in bios.DO factory reset in bios,Try to restart computer check, if issue still persist,remove memory and check. Disconnect hdd and connect on secondard ide or sata connector, tried to reboot and check.remove video card , sound card , modem card or network card if present.connect monitor to onboard video and check.
Aug 17, 2009 | E-Machines eMachines Desktop PC
My Right side SHIFT-KEY on a keyboard of HP-Compaq nx5000 Notebook is not working. Is there any solution?
maybe the under-button rubber is corupted try to clean it
also u can use the left one for a while.
Jun 05, 2009 | HP Compaq nx5000 Notebook
Have ide drive have put a new 60gig but cant load new os it finds the cd drive but wont boot from disk have changed bios but still it say ntdlr missing it drivin me nutts.
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows.
  9. Loose or Faulty IDE/EIDE hard disk drive cable
  10. .
To Fix
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot
Jun 01, 2009 | Fujitsu Siemens LifeBook S-6000 Notebook
NTLDR is missing
You have to reinstall your operating system or to repair it. NTDLR is a system file on the root of c: . Somehow the file got corrupt.
Apr 22, 2009 | ASUS Laptop Keyboard for Asus T9400 Series...
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
Intel D102GGC2 Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
