Question about Gateway M305CRV Notebook
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
  • Gateway Master
  • 32,281 Answers
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Posted on Feb 21, 2009
  • Chris Hingee
    Chris Hingee Feb 21, 2009
    If your CD/DVD drive does not open or close when you push the drive button or select eject from the desktop drive ICON, then you have a faulty disc drive. These drives are removeable, and a replacement drive can be purchased.
  • Matt Bernardi
    Matt Bernardi Jan 06, 2014
    you guys just don''t get it do you? It's a Gateway nE 522 laptop which means that it has no dvd button or paper clip hole. there is no disk stuuck in it and there is NoTHING whatsoever wrong with it. I just want to know the normal non broken procedure for getting the drive to open.. i can'find my computer on this brandd new nightmare
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
How do I eject cd tray on latitude E4310 ?
don't know of that labtop but hit start, hit computer, right click on cd drive hit eject.
Jan 17, 2013 | Dell Latitude E4310 Laptop Computer (Intel...
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
CD stuck.......all eject options do not work...going to start- computor and right clicking on selected drive does not work- error occurred while ejecting DVD RW Drive ...reboot, restart, unplugging has no...
When the cd is stuck and won't eject try looking for a small pinhole on the front of the cd rom drive. This is the "manual eject" or release. Stick the end of a paper clip in there and it should release it.
Nov 10, 2010 | Gateway ZX680003 PC Desktop
Studio 15 laptop the dvd is stuck and no bezel
Try to take the disk out of the computer using the following option
Normally the studio laptops have soft eject for the CD and they dont have a button.. Press and hold the Fn key and then press the F10 key to eject the cd.. Another way is get into computer.. Right click on the DVD/cd rom drive and click on eject... This will work....
If its still not working callup Dell to fix the issue since it might be a issue with the DVD drive even
Oct 22, 2010 | Dell Studio 15 Laptop
Drawer on cd drive won't open model is gateway digital media center gm5260
There are a couple of possibilities here, first it could just be stuck. If you hit the eject button and light flashes, there may be a stuck factor here. Look for the very small hole on the door by the eject button and push an opened paperclip in the hole, this will trigger the manual eject mechanism. With the tray opened feel the way the tray moves along its geared slide. If it seems too tight or it sticks there maybe something mechanical that has happened to it. Try to close it again and try the eject button and see if it will cycle. Also try to right click on the drive itself (Open "My Computer" to view the drives) and click on "Eject" and see if it triggers the command.
Jan 30, 2010 | Gateway GM5260 PC Desktop
My disc drive won't eject.
If there is CD/DVD stuck inside:look for a small hole on the face of the drive and insert a paper clip, and press a bit, the drive will open.
If that does not do the trick, look for an icon on the systray (where the clock is shown) . It represents a square inside which there is disk.The tooltip (bubble) should read Optical Drive Power (on or off). If you click on it it shows a two item menu Power On Power Off with a tick mark near one of them. Click Power ON.
Hope it helps.
Sep 07, 2009 | Gateway Computers & Internet
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
DVD-ROM
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Toshiba A15-S1292 Notebook
Gateway M305CRV Notebook Logo
534 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
