Question about Polar F6 Wrist Watch
Polar F6 - Battery replaced, display corrupt after watch loads.
Hello all,
I have carefully disasembled my Polar F6, replaced the battery with a new CR2032 3V; earthing myself with an anti-static strap to avoid discharge.
When I put the LCD screen back on, all of the symbols and lines are present and strong. When I press a button I get a very dim egg timer with most of the pixles missing, when the watch has loaded itself, I get a very poor display with a lot of pixles missing.
If I reset the watch - holding down all of the buttons except the light - I get the crisp display again showing all of the symbols and LCD cells.
I have taken it apart several times ensuring that all of the clips are firmly in place and are unbent to provide even presure for the LCD contacts but everytime I get a similar result, sometimes better then others, but still with pixles missing. :(
Suggestions welcome.
  • 1 more comment
  • mouseag1999 Apr 09, 2009
    I'm having the same problem.  Got the battery replaced at a radio shack, but now it's having the exact same issue.
  • Adey Hobson-Merrett Sep 11, 2011
    I did manage to get it working properly with some persistance - just needed to get the display seated on the contacts properly. I have now done this process several times on mine and my girlfriends F6 and have not had any problems since. I have learnt to take it apart as little as possible - keeping the display, front metal clip, etc together and then just removing the battery and replacing it.
  • Brian Dudas May 04, 2013
    I have a problem with the F-6 draining the battery completely, only when the rear cover is placed back on. i tried covering the entire back surface of the battery with a sticker, just to make sure it wasn't grounding against the (metal) back cover, and the watch works fine for days until I put the back cover (back) on, then it drains completely overnight. Where could the ground be?
  • 21 Answers
I had the same problem and attempted what banjodoug suggested above. It did not help. I had a faint display even before I re-inserted it into my watch frame. I surmised it wasn't the battery position.
I then took apart the damn thing and put it back together several times, each time rushing to push the setting/center button only to derive the same problem over and over.
I then took it apart one more time and pinched in all of the sides of the metal frame that holds it all together, thinking that I had a bad ground. After I did that, I reassembed it and waited. The display came on with the test display and then eventually went to the standard display on its own and all was good to go.
I suspect the issue was solved by correcting an improper ground and a proper initialization process - both solved by the steps I took above.
Hope it works for you!
Posted on Jun 30, 2009
I had the same problem. It turned out I didn't seat the battery all the way when I put it in. I took it apart and pushed the battery in as far as it would go. Then I put it back together and everything worked. I think the battery was putting too much force on the display when the back cover was screwed down tight. Pushing the battery in all the way solved the problem.
Hope this helps.
Posted on May 10, 2009
I had the same problem. Replaced the battery very carefully; Test display came on; As soon as I pressed a button the egg timer came on and the display was corrupted and barely visible.
I tried the solution recommended by banjodoug. I also clipped the metal cage back on differently - I pressed the clips in diagonally starting with the corner of the battery contact underneath (this lifts up the circuit board in the corner very slightly). Clipping it diagonally this way seemed to seat the circuit board and display better.
Hey presto, the test display came on...I waiting few more seconds and the time came on.
It seems to be working fine now.
Posted on Nov 07, 2010
  • qcyqbcf711 Mar 03, 2011
    I think it also must have something to do with the GROUNDING of the electricity. There is a small spring on the corner of the back inside part which touches the back plate of the watch when the back plate is put back on. I held the spring against the metal back plate AND THEN connected the battery and the display is perfect now. I was having the exact same problem as others. Hope this makes sense. Thanks for others' help.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
I had the same problem and what fixed it for me after trying the options above, was to assemble the circuit board, battery, LCD, and metal clips and then push the side of the circuit board where it was most exposed, against the black plastic of the LCD. Each time I pushed, the display became more clear. My guess is that the contacts didn't line up just right and needed some help. It is working fine now.
Posted on Nov 20, 2013
I had a faint display even after having the battery replaced at an authorized center. So I took apart the watch separating the LCD display from the printed circuit board underneath. I then cleaned all contacts on the PCB on the periphery and put it back together. Now the display is back strong.
Posted on Feb 15, 2012
Hey guys, so i just replaced the battery in my F6 and now it's not doing a thing, is there a reset button i am supposed to push before i close up the back , please help.. thanks
sean
Posted on May 23, 2010
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
Polar F6. After the new battery installed the display is very weak - allmost invisible. Battery is the same type and new for sure. Othervise it works just fine. Beeb sounds are strong and everything. Just...
I had the same problem, the screen would be sharp when adjusting setttings after battery-replacemnet only to fade as soon as seconds after startup.
In my case the solution was to dissasemble the watch, use a toothpick or whatever to remove dirt from the copperplate lines (three long lines and one short line) that connect the hardware-part of the watch to the screen (the backside of the screen has lines that correspond to that of the copperplate lines on the frontside of the hardware-part).
Hope this helps, it worked out great for me!
Oct 31, 2010 | Polar F6 Wrist Watch
Ive just had a new battery in the watch and went to exercise. The watch doesnt seem to pick up my heart rate it keeps displaying 00. Any ideas?
You have to sync your watch. Browse through my tips and you will find link for manual for your POLAR watch.
Aug 04, 2010 | Polar F6 Wrist Watch
What battery do I need for Polar F6?
Always look at the numbers on the old battery first and replace with the same. If you don't have the old battery then I would check with a local business that sells that watch. Sometimes you might find the battery number engraved on the case back. Hope this helps you,.good luck.
Nov 05, 2009 | Polar F6 Wrist Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
Hi i have change the battery in a polar f6 but?
Make sure you don't have the battery in upside down. The large outside case of a button cell is the +positive side.
Feb 20, 2009 | Polar F6 Wrist Watch
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
POLAR WATCH- F11
try a new battery
Jul 09, 2008 | Polar F6 Wrist Watch
Polar F6 Wrist Watch Logo
4,191 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
